manual fuel pump >
manual fuel pump
manual fuel pump
Old 05-03-2011 | 10:05 AM
manual fuel pump
any one know if a 1998 454 mag has a port for a manual fuel pump
IROCKET76 is offline
Old 05-03-2011 | 10:08 AM
no, they have it on the sea water pump ! Its a gen V block.
DareDevil is offline
Old 05-03-2011 | 05:05 PM
not if original block..Gen VI
ezstriper is offline
Old 05-04-2011 | 12:55 AM
No.
You have to run a Sea Pump with the attached fuel pump.
Griff is offline
Old 05-04-2011 | 10:09 AM
I have a serpintine belt system all the pumps with the fuel pump add on are v belts. what then
Old 05-04-2011 | 10:17 AM
Well simply go and buy an electric fuel pump. Very easy install. You can buy them from a decent perf store or summit. Pull old one off plumb new one in and go. Make sure you get one for fuel injection psi needs.
GTOFFSHORE is offline
Old 05-04-2011 | 12:21 PM
I have a Gen VI 454 block (built in Feb 99) sitting in my garage that has the mounting boss and provisions for a mechanical pump. However, you also need to make sure the cam in your engine has a fuel pump lobe on it.
If your engine is a Gen V, then yes, it will NOT have provisions on the block for a mechanical pump.
You can tell the difference by looking at the timing cover. Gen V has the standard stamped steel cover like on the old Mk IV, while Gen VI has an aluminum 6-bolt cover. You can also get the casting number off the back of the block above the coupler housing to determine whether it's a V or a VI.
Budman II is offline
