mpi to carb conversion >
Old 05-18-2011 | 01:20 AM
Default mpi to carb conversion
i would rather sell my whole efi setup and buy an intake carb distributor and coil and call it good. i have no issues with carbs that i can think of and it seems to work for everyone else so what do i specifically need to get to make this work
motor is a 98 502
rectangle port heads
roller cam
bored .034 over
everything new and rebuilt by shop
above is all the same as gen 6 502mag
what size mechanical carb do i need
what kind of distributor would be best( with box or with out)
what kinda of intake manifold
etc!!!
thanks for the help guys!
morrowcarl72 is offline
Old 05-18-2011 | 01:32 AM
800cfm
Merlin or Dart single plane intake manifold
MSD distributor and box
Griff is offline
Old 05-18-2011 | 06:18 AM
just did the same thing....
ezstriper is offline
I have heard nothing but good about these.
http://www.performancedistributors.com/marinedui.htm
1BIGJIM is offline
Old 05-18-2011 | 11:19 AM
My question is- why do you want to do this? The EFI in stock configuration will give you better drivability, somewhat better fuel economy, and better resale value in the long run. Unless you are going on a radical performance build where the EFI setup will not work, I would say you are going backwards. Just my 2 cents.
dogturd21 is offline
Old 05-18-2011 | 11:22 AM
Originally Posted by Griff
800cfm
+2
Best thing I did getting rid of all the MPI. But of course mine was not a mag EFI.
steveh1209 is offline
Old 05-18-2011 | 06:22 PM
EFI is ok for stock setups, from there very expensive to get right with tuning the ECM with mods...pieces for EFI are high $$$ and I can tune a lot on a carb...
Old 05-18-2011 | 06:45 PM
x2 thats what I use
jeffswav is offline
Old 05-18-2011 | 06:54 PM
JasonSmith's Avatar
Really? You can get a custom tune done for under $500.
www.mefituning.com is a great source for tunes.
JasonSmith is offline
Old 05-18-2011 | 08:21 PM
go propless's Avatar
Got rid of my EFI. no more vapor locking for me.
go propless is offline
