Engines dies when shifting, need help here >
Old 06-06-2011 | 01:53 PM
Ok, have been out a couple of times now. Everything working great, no problems what so ever, engines running very nice , tried WOT today, 75mph @ 5500rpm
So what was the problem? Fuel, ignition? I'm not sure, but probably ignition. I found three things that I took care of. First, port ignition key switch was not working properly. Second, ground wire from port alternator was off. Third, there was a very poor clamping with alot of corrosion at two of the three batteries (+).
I cleaned every connection i could find, I replaced all fuses. And I emptied the fuelfilters/separators twice.
Thank you guys for your valuable input. As usual
totto is offline
Old 06-06-2011 | 02:25 PM
88Fount33's Avatar
Beak botr
Originally Posted by totto
Ok, but since I have Bravo's, there are no shift interruptor switches, right? I do have some micro-switches, but I think they just prevents from starting the engines with drives forward (or reverse).
Yep, my post confirms me as a true DA, I knew you had Bravo's and the little switches are so you can't start in gear, I have TRS's now and those switches are on the top of the tranny. But I did have an Alpha boat before this one and it had the switches similar to the bravo ones. Just got the interrupt stuff stuck in my head for some reason.
88Fount33 is offline
