stewart warner gauges >
Old 05-23-2011 | 06:56 AM
mattyboy's Avatar
Default stewart warner gauges
working on older stewart warner gauges, most gauges I have worked on have 3 connections
ignition 12volt
ground
sender
these gauges only have lugs for 2 connections the ignition and the sender. The ground looks to be picked up by the back bracket which has a copper tab which grounds the casing of the gauge. the 2 lugs are isolated from the bracket and the gauge by a nylon bushing.
does the back bracket pick up the ground from the alum dash plate? I didn't see a lug for a ground on the plate plus someone painted the back of the dash plate?
any thoughts??
mattyboy is offline
Old 05-24-2011 | 06:32 AM
LAKESIDE RESTORATIONS's Avatar
Lakeside Restorations.com
Some do use the bracket studs as grounds.
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
