water psi bypass >
water psi bypass
water psi bypass
Old 06-06-2011 | 09:44 AM
Originally Posted by JRider
Yeah, I have one and it has a Watts stamp and part number. Even at $80 it is way over priced.
After looking at this thing it makes me realize i am in the wrong buisness. I need to start making stuff, and labeling it "marine" to triple the profit!
Dumb Q, but I assume the more you screw the dial down, the higher the water psi, to open it?
I was planning on setting it around 15psi. That sound good?
cabin fever is offline
Old 06-06-2011 | 11:18 AM
Yea screw it in for more water psi make your dump line as big as u can. My can not keep up......So I have to play with water pick up tube to get right psi..... 15-18 yea u will have no steam pockets that way.
P.s. it takes some time to set right still working on mine its real close.....make small adj at a time.
skydog is offline
Old 06-06-2011 | 02:26 PM
So what is the Watts part number?
ken sampson is offline
Old 06-06-2011 | 11:33 PM
sosatime is offline
Old 06-07-2011 | 08:56 AM
I just found one on my boat Watts # H560 this goes from
10 PSI to 60 PSI I found them for just under $36.00
Ken
