question about sea pump? >
Old 05-26-2011 | 07:42 AM
I have to prime my sea strainer on first start-up.
thirdchildhood is offline
Old 05-26-2011 | 09:01 AM
I think im going to fill the system as much as I can when im putting the pump back together.
haulinit is offline
Old 05-26-2011 | 09:46 AM
HiPerf2000's Avatar
i ususally assemble the impellor with some grease and also shoot a little liquid soap in the housing. this way there is less friction on the initial "dry start".
HiPerf2000 is offline
Old 05-26-2011 | 11:56 AM
The guy at extreme marine told me to use vaseline, thats probably what I will do I also was told dish soap. Does the boat blow bubbles out the exhaust after you put soap in there ?
haulinit is offline
Old 05-26-2011 | 12:29 PM
HiPerf2000's Avatar
yep....you'll see some soap floating behind the boat the first time you fire it. it helps clean the fish.
Old 05-26-2011 | 12:43 PM
haulinit is offline
Old 05-26-2011 | 09:00 PM
Replaced the impellers and it is now pumping water.
haulinit is offline
