DUI Ignition >
DUI Ignition
DUI Ignition
Old 05-25-2011 | 06:10 AM
Default DUI Ignition
I just switched from a 1996 thunderbolt V ignition to a DUI hei ignition. Q: I have a wiring diagram that says to use the grey wire from the wiring harness and hook it to the tach. I did that but the tach will not work.
ninjaturtle is offline
Old 05-25-2011 | 07:16 AM
call them, should work fine...used them before...
ezstriper is offline
Old 05-25-2011 | 09:20 AM
Anyone ever make this switch?
Old 05-25-2011 | 09:54 AM
It should work, 2 wires to the coil, B+ and tach, not sure of the colors. If I get to the boat I will let you know what color wires I have.
jeffswav is offline
