amp question >
amp question
amp question
Old 05-25-2011 | 08:27 AM
Default amp question
ok one more question , I hade my system installed my a local shop, I have done alot of this back in the day so dont remember if I can take power from the amp that is installed and shortcut it to the new amp or do I have to run power and neg back to the batterys, I would like to just bridge a 1 foot long line
maniac2me is offline
Old 05-25-2011 | 08:53 AM
how big is your power wire, if its 0ga or 2ga you can use a block and split it to both amps if its small it prolly wont be enough to support the extra power
xlt86 is offline
Old 05-25-2011 | 09:24 AM
I'll find out the ga , but also was wondering I have a duel battery set up with a switcher and keep hearing about battery chargers like Promariner Marine Battery Isolators, is this something I should add, I have a 99 yamaha exciter with neons and two amps
Old 05-25-2011 | 12:11 PM
It is completely dependent on what gauge wire is needed for each amp.
Griff is offline
Old 05-25-2011 | 12:16 PM
Yes, we need to know what AWG the wire is, and also how long is the power wire? And like stated above you need a distribution block, DO NOT jump directly from the current amp to the new amp.
stopdropanroll is offline
