power loss--Hard starting after sitting for a hour >
Old 05-30-2011 | 06:50 PM
Default power loss--Hard starting after sitting for a hour
Over the last 2 years the boat has lost some power. At WOT it will maybe turn 4200. I can sweat it use to hit 4700. Then Today after running it for a hour and a half just cruising and putzing around it took a bunch of cranks to get it to go.
The boat it is a 1986 POWERPLAY 23ft 350 cid 260 hp.
Idle maybe to low ?
the Fuel Pump is maybe original, I have not replaced it and I have owned it since 1986 ?
thanks guys,
Steve
powerqrudy is offline
Old 05-30-2011 | 09:21 PM
Engine maybe be getting tired if it is an 1986
firehawkcat is offline
Old 05-31-2011 | 01:02 AM
On a 25 year old engine, it could be anything from a maintenance item/tune up to a complete rebuild.
Griff is offline
Old 06-01-2011 | 08:27 PM
yea it might be time, But I am going with new cap, rotor, coil plugs and set timing before she gets riped out.
Thanks guys,
Steve
Old 06-01-2011 | 09:01 PM
Powerqrudy i would do the things in your last reply they dont cost alot and enjoy the boat this year and replace during the winter
Old 06-02-2011 | 05:54 AM
yea, i think that is the plan.
Old 06-02-2011 | 02:57 PM
It would also be worth running a compression test to see how healthy the internals are. If it's an '86, it's probably just getting tired.
RT930turbo is offline
Old 06-11-2011 | 02:32 PM
ok, i just got a set of NGK UR4 plugs and will put those in tomorrow. Also i am going to check timing and maybe turn up the idle tad.
Will report back.
Thanks,
Old 06-11-2011 | 02:42 PM
Change your filters too. Fuel and water seperator. Whens the last time it had a COMPLETE tune up ?
tinman565 is offline
Old 06-11-2011 | 03:24 PM
Cap and Rotor 2 years ago.. but i maybee put 20 hours a year on it.
i will do the Filters also.
