1998 454 magnum flywheel problem???? >
Old 06-07-2011 | 07:21 PM
GPM
Gas grille works well.
GPM is offline
Old 06-07-2011 | 08:55 PM
Yes I suppose that would work wouldn't it!!! A little hotter a little faster but to much. Good idea!
Baja226sport is offline
Old 06-07-2011 | 09:38 PM
GPM
Worked for me, by the time I tapped the old one off with a block of wood the new one was hot enough to drop right on. You might want to check the starter alignment if you're eating ring gears.
GPM is offline
