502... ?
Old 05-30-2002 | 11:00 PM
checkmate981
Default 502... ?
I have a 502 short block so far and I am looking for a good combo.The short block is basicly a 502 mag bottom end.I was thinking of running WP merlin 310cc 225 188 heads,Crane 113971cam226/236dur.@50 587/610 lift with a 112 cl,850cfm holleyDP with a ? for a intake(Single or dual plane).The only thing I will not have this year is good exhaust.Is this cam and heads too big for stock exhaust ?I want to try to get a happy medium where I can build the engine to where I can run stock exhaust this year and make good with better exhaust next year without doing any changes(.Looking for the best bang for the buck)
Dave ...Aka Slow Guy
Old 05-31-2002 | 07:38 AM
Scott's Avatar
Charter Member #30
Check that cam # and re-post. Make sure you look at the specs of the one you posted
I have Steps & Bubbles!
Scott is offline
Old 05-31-2002 | 06:13 PM
checkmate981
Default I dont no where that# came from.
LOL Very wimpy small block cam .Try 168731.
dave
Old 05-31-2002 | 06:47 PM
I calculate 478 H.P,502 Torque @ 5000 rpm WITH Stock exh. and single plane intake, 8.75 comp.,hope this is close.
253 is offline
Old 05-31-2002 | 07:28 PM
Scott's Avatar
Charter Member #30
I can't say anything bad thats the cam I'm installing in my motors Couple more weeks and I'll have a answer.
BTW HP500 carbs a lot of head work and a tad bit more compression.
Scott is offline
Old 05-31-2002 | 11:10 PM
checkmate981
253 Thanks
What program for the dyno?Scott, do you think this cam is to aggessive for stock manifolds?Let me no how you make out .
Dave
Old 06-01-2002 | 09:32 AM
Scott's Avatar
Charter Member #30
I will post all my results when I'm finished. Sorry I can't answer your question about the stock manifolds. If you plan on replacing them next year it may be a logical choice. I guess the worst thing is that it could be some what restricted till the change over. Scott
Scott is offline
migara422
19
05-26-2005 12:39 PM
XCAV8
18
05-10-2004 09:58 PM
Monty
4
08-20-2003 06:55 PM
RickR
7
08-06-2003 09:27 AM
dennis rider
6
06-11-2003 06:53 AM
