-   -   454 Mag EFI Cyl Head (https://www.offshoreonly.com/forums/general-q/255208-454-mag-efi-cyl-head.html)
snapmorgan 06-05-2011 09:54 PM
I have a 2000 model 454 Mag EFI 385hp that is tired. I am going to build a slightly larger engine, but I need to know if my heads are oval or rectangle port, as I am going to use my current fuel injection setup with a new program. I would like to build the new motor before disassembling the old one because it is still running.
articfriends 06-05-2011 11:57 PM
Your heads are rectangle port, the same ones were used on the 502 also, Smitty
snapmorgan 06-06-2011 06:39 AM
Itsallgood995 06-08-2011 05:36 PM
Friend of mine is in the same boat here. He's considering a cam & possibly a stroker kit. I guess he'll have to reprogram the module if he does any of the above?
snapmorgan 06-08-2011 09:56 PM
If he changes much of anything, he will need to have the ECU reprogrammed. Costs around $350 to have done
