Hatch actuator not working!!!! HELP!!!!! >
Old 06-06-2011 | 06:53 PM
Default Hatch actuator not working!!!! HELP!!!!!
Went out to check a few things and the hatch wouldn't open. I was able to pull it up to fit my arm in and un bolt it. Checked everything I could think of.......
Switch is new and working fine
12.7 Volts in both directions to the actuator
Wire connections are good
the actuator will spin in both directions when you hit the switch, but if you put a load on it, nothing but the noise it usually makes when it is all the way up or all the way down. Will not lift.
Take the load off and hit the switch and spins free again in both directions??????
Baja226sport is offline
Old 06-06-2011 | 07:06 PM
Mine was doing the exact same thing last year. I simply disassembled it, cleaned all the corrosion that it had inside, and re-lubed the screw mechanism. It has worked perfectly ever since.
Darrell.
DMOORE is offline
Old 06-06-2011 | 08:39 PM
How is your battery
firehawkcat is offline
Old 06-06-2011 | 08:44 PM
hope that works. mine did the same thing to me last week
kennyone30 is offline
Old 06-07-2011 | 07:37 AM
Batteries are fine. Gonna take it apart and see what happens I guess!!!
Old 06-07-2011 | 09:27 AM
While you are at it, probably a good idea to install a relay to actuate the hatch motor. It will give you the highest possible voltage at the motor, and it will save your switch. Plus, it will operate much faster. They should come this way from the factory!
Budman II is offline
Old 06-07-2011 | 09:42 AM
Interesting, tell me more.....
