Weird stain on Vinyl HELP?
I used Bleche White a couple weeks ago on my shaggy vinyl.
I've heard it will eat the threads so I kept it away from the seams, but I wasn't too concerned because I hope to get it redone soon. But as a stop-gap, it worked pretty good and made the white look pretty good compared to how it was.
i would say rubbing alochol or goo gone. Also they have a LIFT OFF at Home Depot its safe for cars, clothes, etc. Try that stuff. I used it on a few things now and works good, wipe it on and let it sit for 60sec then wipe it off.
Wait for the sample.....IT WILL remove the stain.
Call Tim at Bio Kleen. He is a chemist and his vinyl cleaner works without destroying your expensive interior.
Do not use any brushes, they are too abrasive. Use contact cement cleaner and rub with a cloth. Rinse with soap and water. Should do the trick unless some of the other chemicals have made the stain set in.
If you have tried all the above, try using mineral spirits. Will put oil back in the vinyl. It will also clean as well. May have to use a little elbow grease to get it to work. Be careful using SPRAY NINE cause it will dry the vinyl out and cause it to crack and using bleack will make the vinyl hard. Good Luck..
