-   -   Mirage plus 25P (https://www.offshoreonly.com/forums/general-q/255714-mirage-plus-25p.html)
Brushwolf243 06-12-2011 10:10 PM
Mirage plus 25P
Bravo X drive
removed my Bravo 1 prop to try 3-blade.. splines stick out pass hub on Mirage plus.. What's happening????
blownhammer2000 06-14-2011 08:43 PM
make sure the spacer is not stuck to the back of the bravo prop and your trying to put the mirage on with no spacer, other than that not sure
Brushwolf243 06-14-2011 09:59 PM
after 3 calls to Mercury, figured out they sent the wrong spline/nut collar with prop
picklenjim 06-15-2011 12:25 AM
What did you need , the concave washer one with the splines in it. What is that Mirage a solid hub?
