no trim under power >
no trim under power
no trim under power
Old 06-13-2011 | 03:21 AM
Default no trim under power
ran my 1998 fever this weekend and the driver wont trim out under full power. they work fine on the trailer and at no wake speed. but after getting on plane i have to back the sticks off and trim out one drive at a time. any help on were to check for my problem.
brians fever is offline
Old 06-13-2011 | 05:56 AM
Audiofn's Avatar
Charter Member #232
Make sure your blue wire is the one getting power when you trim up and the green one when you trim down. They ahve different PSI's and if things are hooked up backwards then that can do this. If it used to work fine and this is a new problem then I would pull one end of the rams off and see if you can turn the end easily. They may need a rebuild.
Jon
Put your best foot forward!
Audiofn is offline
Old 06-13-2011 | 02:18 PM
Hey Brian. Had the same problem before. Turned out to be the pump. Replaced it and all was well.
Its odd that both pumps could have went bad at one time though. Might not hurt, just for giggles, to take the bottom reservoir off the pump. You will find two small pickups with screens on them. Make sure your screens are not plugged up with crap. Trimming up underway requires alot of PSI. I am pretty sure the pumps can be dissassembled, cleaned, and new o-rings installed. Doesnt sound like a electrical issue, but they also do rebuild the motors at some alternator/starter repair shops.
MILD THUNDER is offline
Old 06-14-2011 | 05:30 AM
I think it is electric cuz the fuel gauges drop when I hit the switch.and the halon light will dim. I will start with the grounds.
Old 06-14-2011 | 07:09 AM
Audiofn's Avatar
Charter Member #232
Check your batteries as well. If they are about to die they will not be able to provide enough cranking amps to trim the motors.
Audiofn is offline
Old 06-14-2011 | 07:11 AM
Oh, well then yes, you may be right. Id follow the ground wires from the pumps, and clean them real good. Good luck!
Old 06-14-2011 | 07:47 AM
I had the alternators gone threw and the batterys load tested and they are good
