-   -   Baby Steps, 1st Timer: 1990 Regal Velocity 230 (https://www.offshoreonly.com/forums/general-q/255825-baby-steps-1st-timer-1990-regal-velocity-230-a.html)
rgrgoog 06-14-2011 08:05 PM
Originally Posted by Waveform (Post 3429217)
So what drive shower should I do? I'm not sure what will work with my Latham steering. I thought about one of the halos, but there is already a hole drilled in the cavitation plate.
I have two like this on my Foutain and they work really well.
http://shopping.rexmar.com/Merchant2...riveshowerflex
REDS32 06-15-2011 01:13 PM
Run it and get the bugs out first. When you have it runing right and your use to the boat then if you need more speed go on the swapshop forum you'll find everything you need.
Waveform 07-24-2011 05:46 PM
Ok, time for an update. Had it out three times now, had to replace the following: Coil(MSD), Plugs, cap, rotor, Wires added an MSD 6al(allready had it), Alternator, Powersteering pump with external resevoir, Sea water Impellor and housing, all fluids (20qts of ATF used to flush trim and steering). I have also had to work through allot of electrical gremlins(and former hack repairs). Fixed trim sender and limit plus gauge, and new tach. So yesterday since most bugs are worked out, I got a chance to stretch it's legs on a local small lake. 63 mph on GPS with full tank of gas, two full coolers, my wife and I, and a bunch of stupid families with tubes cutting me off routinely. Considering the one test I found from back in the day said a best speed of 63.3, I figue thats pretty good for 660 hours, a rough bottom(slight blistering), and what is essentially a junkyard Bravo1. Question is, what will it do with better conditions and a lighter load? I was at aprox. 4700 rpm
Padraig 07-24-2011 09:30 PM
Great boat. I had an 89 with a 454mag and lightning headers. Could hit 69-70 anytime and with a good chop and a light load would do 72mph.
Waveform 07-24-2011 11:57 PM
What Prop did you run? The boat came with a cupped 3blade 23p Mirage.
DMOORE 07-25-2011 12:43 AM
[QUOTE=Waveform;3460782Question is, what will it do with better conditions and a lighter load? I was at aprox. 4700 rpm[/QUOTE]
My guess is with a lite load you should be able to pick up about 5 mph. Good to hear ya got the bugs out and were able to enjoy a great day on the water.
Darrell.
Padraig 07-25-2011 11:55 AM
25 inch labbed Mirage. Tried various Hydromotives but the Mirage worked best. The Regal's were more bow heavy then the originals and the Mirage carried it better.
We had alot of fun in that boat.
Waveform 07-25-2011 04:03 PM
I have a spare bravo 25p prop that came with the boat as well, but the previous owner stated that he couldn't get it to rev over 4600 with that prop, and it was a dog out of the hole.
Padraig 07-25-2011 07:20 PM
I am guessing your engine is down on power. )-:
Waveform 07-26-2011 09:36 AM
I'm thinkin its time for a cam, intake and carb.
