Crankcase Pressure >
Crankcase Pressure
Crankcase Pressure
Old 06-30-2011 | 10:10 AM
Originally Posted by ckin62
I tried a different pressure sender and it gave me the same read pattern. I also have 2 other pressure switches (one for a dash light and the other an alarm). When I was test test running they never indicated an issue, but in the driveway at idle they do. So, I don't think it is an easy fix.
You need to throw a mechanical gauge on it - the electrical gauge might have an issue. But it is suspect that it is suddenly reading low.
Budman II is offline
Old 07-01-2011 | 08:12 AM
Oil filter full of bearing material. Pulling to down tomorrow.
ckin62 is offline
Old 07-01-2011 | 10:08 AM
blue thunder's Avatar
Major bummer but at least now you know. A word to the wise, replace all rubber oil lines and oil cooler. Look closely at the piston skirt also for bearing material. It gets in the skirts and wrecks them.
blue thunder is offline
