Tulipped valves >
Tulipped valves
Tulipped valves
Old 06-16-2011 | 11:43 AM
Default Tulipped valves
I have had some small block chevy intake valves tulipped my latest is a 350 with #2 #6 & #3 intake valves pistons are fine combustion chambers in good shape didn't go lean all cyls are black like it was rich has anyone have a idea what causes this
forcefed1471 is offline
Old 06-16-2011 | 12:00 PM
What kind of valves are they as well as size and how much time on them. Spring pressure, etc.
getrdunn is offline
Old 06-16-2011 | 12:23 PM
Prolonged periods of running just on the edge of detonation/high cylinder temps will result in tuliped valves. Detonation not quite severe enough to blow head gaskets etc., so it goes un-noticed. Timing and lean air/fuel mixture would be the most likely causes. It's not only possible, but likely, that it IS lean at some point in the operating range. The fact that the chambers/valves are black right now means very little relative to the conditions during which the damage is occuring.
cubicinches is offline
Old 06-16-2011 | 12:25 PM
motor is a 350 vortec all factory stock
Old 06-16-2011 | 12:38 PM
just found out this is a JASPER MOTOR with approx. 1 hour of run time on it customer & the installer had a fallin out now I find myself in the in the middle
Old 06-16-2011 | 12:51 PM
A marine based unit and not out of a truck?
Wannabe
wannabe is offline
Old 06-16-2011 | 12:52 PM
yes marine motor
Old 06-16-2011 | 01:01 PM
Strip Poker 388's Avatar
Rob
Ive had a 2 buddies with cruisers with Merc small blocks do the same thing,was told it was the low octane/87 and didnt have a good grade stainless valves.
Strip Poker 388 is offline
Old 06-16-2011 | 01:31 PM
What RPM are you running at WOT?
olmako20 is offline
Old 06-16-2011 | 01:48 PM
I had the same thing happen on my 730 hr. 1995 350 Mag. Most likely a bad fuel, age, and detonation issue coupled with a few injectors getting gunked up. It culminated in the #1 exhaust seat failing and sharing the crunched up pieces with #2 & #4. While doing so it punched a hole in the head near the #1 spark plug breaching a coolant passage.
At least half if not more of the intake valves were tulip'ed.
Trash is offline
