500 efi short block questions >
Old 06-20-2011 | 12:04 PM
Steel Outlawed's Avatar
Default 500 efi short block questions
I spun a rear main bearing in my port 500 efi. I was wondering if Mercury used a stock high performance short block for their 500 efi short blocks? Or did they assemble their own short blocks? If they did not use the gm assembly what are the differences? The top end of my engine was completely redone about 100 hours ago and it looks great. I'm just trying to get back on the water as soon as possible, so I'm looking into as many options as I can.
Are the marine block different alloys or do they use the same block marine and auto?
Thanks in advance,
Jeff
Steel Outlawed is offline
Old 06-20-2011 | 12:37 PM
Yes
Other than the camshaft, it's all the same stuff.
cubicinches is offline
Old 06-20-2011 | 12:49 PM
Is the ZZ502 the one I would want to get to replace the 500 efi?
Old 06-20-2011 | 12:50 PM
Absolutely... Just use your stock 500EFI camshaft.
Old 06-20-2011 | 02:34 PM
Most of the 500 EFI's used a manley H beam rod.
I dont think the ZZ502 does.
JaayTeee is offline
Old 06-20-2011 | 03:08 PM
I think I remember somebody that was giving me a quote on a rebuild said they we would upgrade the rods h beam rods, so I'm not sure if they come with the h beam rods or not.
Old 06-20-2011 | 03:09 PM
Absolutely not...
Old 06-20-2011 | 04:15 PM
Ted G's Avatar
Mine did and they say Merc Racing on them.
www.cbpba.com
Ted G is offline
Old 06-20-2011 | 04:42 PM
As did the pair of 02's I just did.
JaayTeee is offline
Old 06-20-2011 | 05:15 PM
Perhaps the H beam rod is something they started in the later 500EFI's. I've done quite a few 500's, the newest ones being a pair from an '02 Top Gun, and have never seen anything in them but a GM rod. Obviously, they must have used them in some of the later ones.
