machine marine steering upgrade >
Old 06-22-2011 | 07:08 PM
Default machine marine steering upgrade
whats required to change from 1/2 system w/stock cable to full hyd. system ? have machine marine dual ram setup now.. thanks Rob
ezstriper is offline
Old 06-22-2011 | 09:24 PM
Rookie's Avatar
You would need a hydraulic helm, 3 High pressure hoses: 1 from power steering pump to the helm, 2 from the helm to the transom bulkhead fitting and 1 Low pressure return hose back from the helm to the power steering pump. And a few fittings. I bought the hydraulic stuff from my local Parker store and my helm pump off of eBay.
Rookie is offline
Old 06-23-2011 | 12:26 AM
Just as Rookie said. Nothing on the outside in the rear will change. You will need the helm and dash bezel, about 60 feet of high pressure hose (2250-2500 psi), high pressure hose ends, about 20 feet of low pressure return hose, hose ends for low pressure hose, filter, extra reservior, etc.
You can use a helm and hose kit from anyone. It doesn't have to be from Marine Machine. IMCO and Mayfair both have reasonably priced kits. Expect to pay around $1000-$1200.
Let me know if I can help.
Eddie
Young Performance is offline
Old 06-23-2011 | 01:41 PM
thanks...Rob
Old 06-23-2011 | 02:40 PM
You can also completely do away with power steering pump and get a hydraulic helm pump and reservoir.That's what I did and was WAY easier...
Mind you, I didnt have steering pumps on my motors to begin with...
Rambocj7 is offline
Old 06-23-2011 | 10:49 PM
I am wanting to do the same thing to my boat. I also have the Marine Machine with dual rams on my single Bravo. CP has two different kits that I have been eyeing up. One is the delux kit for $1,600, the other kit is the basic kit for $1,300.
cloudmaster_321 is offline
Old 06-24-2011 | 06:21 AM
need to keep the P/S pump as I'm running a single belt
