Melted rubber exhaust hose replace with stainless? >
Old 06-30-2011 | 08:44 PM
  #41
Originally Posted by GPM
Just wondering if they were burnt and if the water holes lined up between manifold and riser.
The risers have "jumper" hoses for a dry joint. The gaskets looked a little compressed and a little warmed up if that's a way to describe them. They were still compressable and weren't burnt on the edge where the exhaust gas passes. Thanks for following and quizzing me as to what to look for.
pitts1313 is offline
Old 06-30-2011 | 10:01 PM
  #42
Default I am impressed
Out here in the sticks I dont come across these kind of boats. But you guys really know your ****! I am impressed and I am not being a smart ass. Just a complement.:}
BAD ASS SCARAB is offline
Old 07-01-2011 | 10:29 PM
  #43
Got the stainless exhaust tubing working. Water pressure was 22-25 psi while running so I'm good. Water temps ranged from 110 at idle to 180 while under way. Oil temp was 180-190. I had what I hope is a fluke when the oil temp spiked to 350*rapidly and sounded the alarm. Turned engine off immediately and then turned the key back on and it climbed from zero to only 190*. Do new senders cost much?
Old 07-05-2011 | 06:29 PM
  #44
JasonSmith's Avatar
New senders are cheap. Probably under $50 depending on your gauge MFG.
JasonSmith is offline
Old 07-05-2011 | 09:30 PM
  #45
US1 Fountain's Avatar
Ginger or Mary Ann?
How did your pressure go from 40psi with bad impellors, to 22-25 with new impellors?
US1 Fountain is offline
Old 07-06-2011 | 07:04 AM
  #46
Uhhhhhhhhh, little embarrassed, I got excited when every thing went hay wire, I read the oil pressure gauge instead of water pressure. I was overwhelmed with gauges.
Old 07-06-2011 | 09:14 PM
  #47
Offshoreonly Advertiser
pitts1313,
If you really want to keep an eye on what is going on with your water flow, as pressure can easily be inaccurate as a kinked hose or restricted heat ex-changer would give you a false understanding of what is happening. Check out this NEW product Livorsi is offering!!
http://www.livorsi.com/pdf/water_flow_system_flyer.pdf
bbcmi is offline
Old 07-07-2011 | 08:35 AM
  #48
Originally Posted by bbcmi
pitts1313,
I need this....I can't count how many sea pumps I've went thru due to sea strainer getting plugged and reducing flow and not knowing till alarm goes off and pump is ruined. I also attribute my issues with my IMCO lower unit with only a low water pickup sucking up sand alot.
Baja_man is offline
