Can this happen again? >
Old 06-29-2011 | 05:54 PM
Just for info I built a 505 and kind of followed the lines of the merc 460 cyclone which I have the manual on with all the specs. They ran a 850 dp on an aluminum dual plane. The jets called for in the manual are 84's front and rear. This is a 454 stroked 1/4" which made it 482 inches which they made back in the 80's. Only thing it has rectangular port heads if that makes a difference.
picklenjim is offline
Old 07-08-2011 | 07:06 AM
offthefront's Avatar
Originally Posted by mrfixxall
Emi's SS risers will condensate if theirs not enough heat in the water temps..run the boat and pull the risers and you may see white spots inside..
naw .... they never leak ......m
offthefront is offline
Old 08-04-2011 | 10:49 AM
35fountain's Avatar
That looks like stock merc exhaust..My EMI's don't have water slots like yours show
35fountain is offline
