manifolds??? >
manifolds???
manifolds???
Old 07-02-2011 | 02:55 PM
Default manifolds???
anyone know what manifolds these are? they have no markings in them, there light, and the exit to the riser is round.
I need risers for silent choice and would like to know which ones to order.
Attached Thumbnails manifolds???-new-454-001.jpg   manifolds???-new-454-002.jpg   manifolds???-new-454-023.jpg
zeke is offline
Old 07-02-2011 | 02:56 PM
Default Fixx
they are gils..Dependine on which cam is in the engine you may not be able to run the shorter riser
FIXX is offline
Old 07-02-2011 | 02:59 PM
wouldnt the silent choice make the short ones longer?
zeke is offline
Old 07-02-2011 | 03:16 PM
Default Fixx
yes but you will need to worrie about reversion whicj gil;s are known to have a problem with..need to know the cam specs first before you change them..the longer the tube and the further back in the tube where the water blends with the exhaust the less chance of reversion..
this is what you need if you choose to go with the silent choice..
http://www.offshoreonly.com/forums/s...il-risers.html
FIXX is offline
Old 07-02-2011 | 03:26 PM
if you want give me your email and i can send you a pic on how to modify yours to make a shorter riser and may work for your application.
FIXX is offline
Old 07-02-2011 | 05:00 PM
thanks for youre help, motors are unknown specs was told they were 500 hp 454's i paid 5 grand for the pair. im gonna pull the other one apart and figure out what there all about. my email is [email protected]
zeke is offline
