That fuel line is for a car...
This will work for your boat http://www.jegs.com/i/Russell/799/641090/10002/-1 |
Fuel leaking issues
Well well I thought I was the only one who spends the best holiday weekends working on there boat and having any fun on it!!.... lol
I also had a fuel leak with steel lines and tried a few types of lines one just like the one you have pictured the other was when I went to the auto parts store bought some high grade line and made my own only to have the places that I flared crack and break! I talked with a few HP boat shops and they ALL told me to run steel braided lines ! I checked with the USCG and they said yes they are good. I found out all the USCG line is for is to buy you more time to either get the fire out or get off the boat ! Thats it and any line with braided covering is going to buy you more time! I bought a line kit from summit and all of the fittings needed to make the line from the tank to the carb steel braided. Have been checked out by the law and passed...... and no more fuel leaks.. :-) |
well i found one of those copper crush washers for a flare fitting at lowes today, fixed that leak immediately. now the 3/8 pipe threads going in and out of my fuel pressure regulator have a small leak... man one thing after another!!
So whats the best sealer to use on pipe threads in a fuel system?? i know my OEM stuff had some red sealer on it but no idea what it was??? |
I use nothing but braided line for everything with AN fittings. A little more costly but in the long run works the best. i wouldn't use a ridgid line at all. There's alot of vibration and eventually it will crack, especially on a fuel line after the pump. Big problem real fast!
He asks for advice....but doesnt wanna listen. :picard1:
I never heard of a crush washer for a flare fitting. i don't really do my boat engine shopping at lowes. or my auto shopping either for that matter. The flare makes the seal, usually. i don't know, maybe I've been doing it wrong all these years? It's gonna leak, mark my words, it's only a matter of time. Just hope it doesn't blow up when it does, but they always have to have that pretty chrome line. JUNK!
:eek:
Originally Posted by gsxr1216
(Post 3444172)
So whats the best sealer to use on pipe threads in a fuel system?? i know my OEM stuff had some red sealer on it but no idea what it was??? No pipe sealer :eek: |
I don't make it a habit of buying my marine parts at auto parts stores either.
After checking with a few boat performance shops they all said NOT to hard plumb the fuel system even though the manufacture does ! I was told that with all of the vibrations the engine has even more so when you mod one with a bigger cam & headers different RPM range that your asking for trouble if you hard plumb ! I noticed that Jeggs & summit have some marine parts listed so I gave them a call. Summit set me right up with all of the lines & fittings needed to use 1/2" steel braided lines from the tank to the carb and have been trouble free for 3 yrs now....... |
Originally Posted by 35fountain
(Post 3444304)
:eek:
NONE No pipe sealer :eek: Scuse me??????????? NPT threads are supposed to be sealed with either tape ( not for fuel systems ) or thread sealer. If you crank a brass fitting into an aluminum housing with NPT threads tight enough not to leak under pressure, the aluminum threads are now permantly phucked. |
The tape only acts as a lubricant. The wedge action of the tapered threads is what does the sealing. :drink:
| All times are GMT -5. The time now is 02:15 PM. |
