Gen VI Mag piston rings? >
Old 07-06-2011 | 09:51 AM
Default Gen VI Mag piston rings?
I am re-ringing a 1996 454 Magnum MPI and the rings I bought don't fit on the oil ring side. I looked on here and found a few posts but I want to be sure before I buy another set of rings. What rings have the low tension oil rings needed? I am still using the standard bore too.
seansmp8 is offline
Old 07-06-2011 | 10:33 AM
call the guys at total seal. they will id the pistons you have and the ring pak you need. its good stuff and they are very helpful
stevesxm is offline
Old 07-06-2011 | 04:03 PM
what pistons ? SRP ? ck with piston manufacture..seen some oddball ring combos in these things...
ezstriper is offline
Old 07-06-2011 | 06:31 PM
They are the TRW fordged pistons, stock for the mag.
seansmp8 is offline
Old 07-06-2011 | 08:56 PM
Sean,
They might be a metric ring setup. They are not low tension, but have a shallow oil ring groove. Probably Hastings 2M4718 Your machine shop should be able to measure them for you and probably can get you the rings as cheap as anyone else.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
BillK is offline
Old 07-07-2011 | 06:34 AM
Sean,
Your PM box is full. My number is 301-843-5700
Bill
BillK is offline
Old 07-07-2011 | 07:59 AM
seen SRP used in stk mags as well....
