454...is it a HO or not? >
Old 07-11-2011 | 11:08 PM
Default 454...is it a HO or not?
how can you find out the power rating of a 454 mag?
tnc110 is offline
Old 07-11-2011 | 11:30 PM
Default Fixx
if it reads 454 mag and its a efi engine its most likely a 385 hp version..take the serial number iff the side of the block or on the intake and call merc.
FIXX is offline
Old 07-11-2011 | 11:59 PM
Or post the number here, I'm sure someone can look it up for you.
lakematdude is offline
Old 07-12-2011 | 02:07 AM
365 HP if its carb'd and 385 if its EFI
Powerquest_Baby!! is offline
Old 07-12-2011 | 08:44 AM
Ok004424
tnc110 is offline
Old 07-12-2011 | 09:40 AM
Serial Number Range
454 MAG. BRAVO (GEN. V) GM 454 V-8 1996-1997
0F801700 - 0K999999
FogduckerIII is offline
Old 07-12-2011 | 04:20 PM
Ok004424
Serial number OK004424, Model number 4454110KS 1997 MERCRUISER W/PS, TWO PC EX, GEN 6, 454 BRAVO, with a carburetor = 350hp.
See page 1B-4
http://www.boatfix.com/merc/Servmanl/16/16B1R2.PDF
Old 07-13-2011 | 10:57 PM
So, does that mean it is or is not a ho engine? Forged internal rather than cast?
See page 1B-4
tnc110 is offline
Old 07-13-2011 | 11:49 PM
The is no such thing as an HO engine for a Merc 454. Its either a Magnum engine or its a regular 454/7.4. The 454magnums have all good forged internals.
The 350 hp rating is at the prop. Its rated 365hp at the crank.
Griff is offline
Old 07-14-2011 | 07:05 AM
Thank you.
tnc110 is offline
