BBC 2 Bolt main block hp limits? >
Old 07-19-2011 | 12:05 PM
Originally Posted by ezstriper
probably more than the bravo can handle...raced 2 bolt main blocks at a lot more power in a drag car than boat will see, never a failure !!!
X 2
Jeff P31 is offline
Old 07-19-2011 | 02:19 PM
Thanks everyone!
Steve
smiklos@sunprint is offline
Old 07-19-2011 | 04:15 PM
Originally Posted by Rookie
Ok, what about a 2 bolt with splayed caps???? Is this a myth or are they stronger???
State you case!
No such thing of a 2 bolt only splayed....a 4 bolt splayed would have the center 2 bolts straight and the outer 2 on an angle. Definately stronger as it counteracts the side forces of the crank. The limitations here are the cast crank, which will fail long before the block gets hurt.
Snakebite A-82 is offline
