Need Help ASAP >
Need Help ASAP
Need Help ASAP
Old 07-23-2011 | 08:29 AM
Default Need Help ASAP
fixed.
it was a combination of things!
ar15meister is offline
Old 07-23-2011 | 09:34 AM
fireboatpilot's Avatar
RIPSTA Racing Team
Not sure what the GPS speedo has to do with the MSD box? Did you check your main breaker?
fireboatpilot is offline
Old 07-23-2011 | 10:13 AM
Originally Posted by ar15meister
Out running yesterday. boat was running great. all of a sudden gps speedo and rpm gauge went haywire and i began to back off and the boat quit.
wont start up had to be towed in.
I am thinking it is my msd box. I just had the motor out and it seems as if the msd was hooker to the battery and the starter by the shop. could this be the reason for the failure?
primary power supply wire to the dash/ignition switch maybe... but the msd does run the ignition and the tach and those bosxes are really junk. check the wire at the dash or and at the master plug at the motor. and throw away the msd anyway and put something good in... like the stock stuff.
stevesxm is offline
Old 07-23-2011 | 10:39 AM
Audiofn's Avatar
Charter Member #232
My thoughts as well. GPS going haywire makes me think you have an electical issue. Did you check the easy stuff like volts at the battery and alternator?
Put your best foot forward!
Audiofn is offline
