Wiring diagram >
Wiring diagram
Wiring diagram
Old 08-01-2011 | 09:02 AM
Default Wiring diagram
Anyone have a wiring diagram for the intrument panel on a ('08 42) Fountain ? I have lost power to all gauges as well as compass and depth finder. It's probably a simple fix if I knew where to look.
dbl trbl is offline
Old 08-01-2011 | 09:41 AM
Did you check the kill switch. I triggered my some time this spring cleaning and did the same thing.
1BIGJIM is offline
Old 08-01-2011 | 09:42 AM
Does the motor(s) still start? Sounds like a fuse. Most rigs have a hot wire coming off the ignition key switch it may have become corroded or disconnected, also check to make sure that the ground is good.
Cliff
cliff_m_b is offline
