Mag Vs HO engines >
Mag Vs HO engines
Mag Vs HO engines
Old 08-04-2011, 06:07 AM
Originally Posted by CrownHawg
ZX, I'm curious about the switch from mags to HOs. I have been considering converting my two 496 mags to HOs but have reservations on how this would affect my reliability. My two 375s will push my 32 Victory w/28p 4 blade bravos to around 77 now(a little faster in cool water), and would be curious of how much gain I could expect.
i have more than 500 HRS after the cam and ecm swap with no issu (easy job)like i said on my boat it was about 3 4 MPH i dont know wit 2 engine maybe 5- 6 mph ???.i dont drive the boat to hard,most of the time between 3500-4000 RPM.
zx14k is offline
Old 08-04-2011, 07:37 AM
ZX, that sounds great! I spoke with Bob L this summer and he was fairly optimistic as to reliability as well. I figured I could possibly turn a set of 30p props if I went with the HO setup. I am borderline right now turning the 28s at 4700-4800. It came with 26s and they were waaaayy too short, running around 5000-5100. Still pondering.
CrownHawg is offline
Old 08-04-2011, 08:47 AM
by my experience i think that you will keep the 28 but you will turn them to 5000-5100.the REV alarm on the HO is 5150.on my baja with the mag and a mirage + 23 the best was 4800, with the HO 5050 on the smartcraft digital RPM.i made the swap in 2002 at this time i have to buy cam and new ecm from mercury but now i think that you can have the ecm reflash and a better cam.you can contact raylar 866-496-8181
858-277-1109_fax
for technical info [email protected]
for sales and services [email protected]
for accounting [email protected]
for vendors and distributors [email protected]
if you plan to do the swap yourself i think i can scan the section in the shop manuel that explain how to do it,the only special tools you need is a puller and a torque rench and a tool to disconec the fuel suply to the rail.
zx14k is offline
Old 08-04-2011, 09:35 AM
Merc website states the HP of the Mag at 375 and the HP of the HO at 425. I'm sure it varies with each motor though.
Originally Posted by onesickpantera
Yep and most Mags dyno around 390-395. Again, just what I have read no first hand experience.
According to Dustin @ Whipple who have done alot of testing, they are within 2% of their rated power. (He uses SAE ratings, so it's the same as merc)
If you are running 77 on average, 82ish should be the number, and maybe 83+ on the cool day with the sun in your back ect.
Oh and don't you also have to change th TB?
A.O. Razor is offline
Old 08-04-2011, 10:39 AM
NO you only have to drill the existinng hole in the throttle plate to1quater.it is not a must but the idle will be smoother.
zx14k is offline
Old 08-04-2011, 10:50 AM
That'd be nice! Oh, and no, I wouldn't do it myself. It would be a winter project for a "professional".... I know just the man.
Old 08-04-2011, 11:29 AM
anyway if you need the the part of the shop manuel shoot me a e mail:[email protected]
zx14k is offline
Old 08-04-2011, 12:16 PM
Thanks! I may take you up on that!
Old 08-07-2011, 08:09 AM
zx14k...where are you from?...with a name like that,you're probly not far from me !!
pqjack is offline
Old 08-07-2011, 08:41 AM
i am from sherbrooke PQ most of my boating is on the lake memfremagog.
zx14k is offline
