impeller and housing >
Old 08-11-2011, 01:09 AM
Default impeller and housing
where can i find an impeller and a housing for a 496mag? my mechanic told me he cannot get the housing and that it is back ordered several months...? is he blowing smoke?
thanks
chewyjr18 is offline
Old 08-11-2011, 01:32 AM
Received 1,821 Likes on 907 Posts
http://www.mercruiserparts.com/
Griff is offline
Old 08-11-2011, 03:20 AM
im new to the bravo one always had alphas and my alphas had the water impeller in the lower unit of the out drive is the seawater pump the same thing? if so i would just need the rebuild kit which is readily available online?
Old 08-11-2011, 05:26 AM
i just put a new impeller on mine last year and all work fine.
zx14k is offline
Old 08-11-2011, 06:48 AM
SunsationalMate's Avatar
Thumbs up Rebuild kit install.
Here's a diy guide.
http://www.sunsationboats.com/forums...ead.php?t=4779
SunsationalMate is offline
Old 08-11-2011, 11:57 AM
The sea water pump for Bravos is mounted on the engine.
Griff is offline
Old 08-11-2011, 12:10 PM
If the pump housing is scored at all replace it
Unlimited jd is offline
Old 08-11-2011, 07:56 PM
Biggus's Avatar
I think Hardin Marine makes a replacement for the 496
Much less than the Merc part.
Biggus is offline
Old 08-12-2011, 08:48 AM
Yes, I would recommend the Hardin Marine pump. It is a stainless replacement for a bronze body. Much more durable and a bit cheaper.
http://www.hardin-marine.com/p-15774...d-502-mag.aspx
Baja_man is offline
Old 08-12-2011, 09:34 AM
if its older the housing is discontinued and you have to get the new one and either it will fit or modify it somehow.
soldier4402 is offline
