Holley 850 help >
Holley 850 help
Holley 850 help
Old 08-13-2011 | 09:52 AM
bigboat28's Avatar
Default Holley 850 help
Carb has been rebuilt and still cant get to stop popping and missing and stumbling off idle. Once it gets going up around 2000 rpms it smooths out. Any ideas?
bigboat28 is offline
Old 08-13-2011 | 09:53 AM
bigboat28's Avatar
It has 6.5 power valve in front, plug in the back and the jets are 96's.
Old 08-13-2011 | 01:04 PM
What are some of the engine details. Those are some big jets.
picklenjim is offline
Old 08-13-2011 | 01:07 PM
I agree. Are you sure you dont have a vacuum leak somewhere ?
tinman565 is offline
Old 08-13-2011 | 01:34 PM
bigboat28's Avatar
They are gen VI chevy 454's crate motors, with dry exhaust, crossovers, and electric chokes.
Old 08-13-2011 | 01:36 PM
bigboat28's Avatar
Supposedly 425hp.
Old 08-13-2011 | 02:13 PM
Default Fixx
Are you running thermostats with the cross overs?? Holleys hate it when they are cold..long process and its hard to diagnose over the key board..post a video on youtube and let us hear what its doing and we can some how figur it out..first i would make sure the timing is spot on,,the air fuel mixture screws and idle set screw go hand in hand with each other,,if the idle set screw is set to high the engine will run out of its idle circuit and will stumble at all times..pm me your phonne number and i will call you to go over some things..
FIXX is offline
Old 08-13-2011 | 02:16 PM
bigboat28's Avatar
No thermostat and timing is correct.
Old 08-13-2011 | 03:34 PM
Is the back of the transom blackishly sooty ? Who jetted the carbs ? Who dialed in the carbs after they were installed on the motor ? Float levels good ? Air mixture screws adjusted right ? Proper base gaskets used ? Carbs tightened down correctly ? Air bleeds clear ?
I personally think thats a little too much carb for your motors....and I also think your way heavy on the jetting.
Old 08-13-2011 | 06:52 PM
Too much jets. I run 89 front and 86 rears on my 468 now and I still think it's too rich!
Also, your static timing plays a big role with idle smoothness too.
My thoughts are your jets are off though. I'd start there and see how you go.
Good luck!
Ghostrider is offline
