need a hei distributor for a 94 502 EFI
I looked at my junk original 502 mpi oem distributer and on the bottom it does have screens and a uscg approval, so they DO certify them but I'm not sure the oem doesn't also have the screens, I doubt it has that uscg cert though!
Ezstriper-never seen or heard of a timing module in these 2 plug distributer, I know IF you buy the msd it is the same for a car and a boat and they never mention different timing curves, Smitty
So do you guys think this will work ?
http://www.autozone.com/autozone/par.../N-j1ylnZ9n80u.
And Thx so much for your replies and insights.
Thats the one I was talking about, if you look too they sell a new one all brand new for 25 more dollars and the core charge on the re-manned is 23.99 so I would really consider buying brand new, I see it does have the screens on bottom too, Smitty
Smitty, it's CFM, - the distributors (Merc vs GM) are identical.
Screens, etc,etc.
Merc just charges a little more. LOL.
I like the Accel Cap/Rotor or any other with brass terminals. The GM/Merc has aluminum terminals.
BTW: the modules do have timing curves. 22 degrees all in by 2800rpm. Pretty good one for performance carb motors. Yes, I said carb. Have used them that way too. When used with EFI, the ECU will have it's own timing data of course.
Screens, etc,etc.
Screens, etc,etc.
Screens, etc,etc.
When used as EFI, I have just set base timing. I have not done any programming on the MEFI's so have had no chance to check.
The advance curve in the module is the following:
RPM = Advance
700 = 11°
750 = 12.5°
800 = 13°
1000 = 15°
1250 = 16°
1500 = 16.5°
1750 = 17.5°
2000 = 18.5°
2250 = 19.5°
2500 = 20.5°
2750 = 21.5°
2800 = 22°
3000+ = 22°
my marine EST dist's that came in my crusader marine engines have NO screens in them..all original, also have one new one of the as it the special reverse rotation one that the put a extra bearing the top to absorb the load..whole story on that..on the advance deal,theses are the ones that have the 2 wire timing system w/no ECM GM has the specific modules(or at least they did) like one for a 87 IROC 5.7 TPI was not the same as a 92 TBI from a truck..was told it was all in the timing curve...now when you buy one from a auto parts store...they have the one size fits none...all the same so ??? not sure how much different they are..was told by a ign expert that one from a 87 IROC/vette 5.7 TPI were the best ones to run..and DO NOT ever run a generic auto parts one..also years ago I bought a dist fro my 91 suburban form advance auto, noticed when I put it in was totally different, pick up , module were NOT like the GMs at all and nothing would interchange ?? it failed 2 years later....
My problem is when it gets alittle corrosion it creates a igntion short,kills the motor.
The acdelco have made in singapore on them,but looks like it has a non corosive male pins on it, the Merc says made is usa and the 2 pins corode/rust and turn green.
good info here
http://www.megamanual.com/ms2/GM_7pinHEI.htm
I think the module is the same in them,GM 7 pin
#D1943a
10482827
Oreilys list it the same for
http://www.oreillyauto.com/site/c/de...2801&ppt=C0334
Fits,applications show for
1988 Pontiac Fiero V6-173 2.8L
1988 Pontiac Firebird V6-173 2.8L
1988 Pontiac Firebird V8-305 5.0L
1988 Pontiac Firebird V8-350 5.7L
1988 Chevrolet Monte Carlo V6-262 4.3L
1988 Chevrolet Monte Carlo V8-305 5.0L
1988 Chevrolet Full Size Chevrolet V6-262 4.3L
1988 Chevrolet Full Size Chevrolet V8-305 5.0L
1988 Chevrolet Full Size Chevrolet V8-307 5.0L
1988 Chevrolet Full Size Chevrolet V8-350 5.7L OHV
1988 Chevrolet Camaro V6-173 2.8L
1988 Chevrolet Camaro V8-350 5.7L OHV
1988 Chevy Truck C+k 1500 - 3500 P/u V8-454 7.4L
1988 Chevy Truck Blazer Full Size V8-350 5.7L
1988 Chevy Truck G 10,20,30 Vans V6-262 4.3L
1988 Chevy Truck G 10,20,30 Vans V8-305 5.0L
1988 Chevy Truck G 10,20,30 Vans V8-454 7.4L
1988 Chevy Truck P 10,20,30 Vans V8-350 5.7L
1988 Gmc Truck C+k 1500 - 3500 Pu V8-454 7.4L
1988 Gmc Truck Jimmy/yukon Ful Size V8-350 5.7L
1988 Gmc Truck G 1500 - 3500 Vans V6-262 4.3L
1988 Gmc Truck G 1500 - 3500 Vans V8-305 5.0L
1988 Gmc Truck G 1500 - 3500 Vans V8-454 7.4L
1988 Gmc Truck P 1500 - 3500 Vans V8-350 5.7L
1989 Pontiac Firebird V6-173 2.8L
1989 Pontiac Firebird V6-231 3.8L
1989 Pontiac Firebird V8-305 5.0L
1989 Pontiac Firebird V8-350 5.7L
1989 Chevrolet Full Size Chevrolet V6-262 4.3L
1989 Chevrolet Full Size Chevrolet V8-305 5.0L
1989 Chevrolet Full Size Chevrolet V8-307 5.0L
1989 Chevrolet Full Size Chevrolet V8-350 5.7L OHV
1989 Chevrolet Camaro V6-173 2.8L
1989 Chevrolet Camaro V8-350 5.7L OHV
1989 Chevy Truck Astro Van V6-262 4.3L
1989 Chevy Truck C+k 1500 - 3500 P/u V8-454 7.4L
1989 Chevy Truck Blazer Full Size V8-350 5.7L
1989 Chevy Truck G 10,20,30 Vans V6-262 4.3L
1989 Chevy Truck G 10,20,30 Vans V8-305 5.0L
1989 Chevy Truck G 10,20,30 Vans V8-350 5.7L
1989 Chevy Truck G 10,20,30 Vans V8-454 7.4L
1989 Chevy Truck P 10,20,30 Vans V8-350 5.7L
1989 Gmc Truck Safari Van V6-262 4.3L
1989 Gmc Truck C+k 1500 - 3500 Pu V8-454 7.4L
1989 Gmc Truck Jimmy/yukon Ful Size V8-350 5.7L
1989 Gmc Truck G 1500 - 3500 Vans V6-262 4.3L
1989 Gmc Truck G 1500 - 3500 Vans V8-305 5.0L
1989 Gmc Truck G 1500 - 3500 Vans V8-350 5.7L
1989 Gmc Truck G 1500 - 3500 Vans V8-454 7.4L
1989 Gmc Truck P 1500 - 3500 Vans V8-350 5.7L
1990 Pontiac Firebird V8-305 5.0L
1990 Pontiac Firebird V8-350 5.7L
1990 Chevrolet Full Size Chevrolet V6-262 4.3L
1990 Chevrolet Full Size Chevrolet V8-305 5.0L
1990 Chevrolet Full Size Chevrolet V8-307 5.0L
1990 Chevrolet Full Size Chevrolet V8-350 5.7L OHV
1990 Chevrolet Camaro V8-305 5.0L
1990 Chevrolet Camaro V8-350 5.7L OHV
1990 Chevrolet Camaro V6-191 3.1L
1990 Chevy Truck R+v 10,20,30 P/u,sub V8-454 7.4L
1990 Chevy Truck Blazer Full Size V8-350 5.7L
1990 Chevy Truck G 10,20,30 Vans V6-262 4.3L
1990 Chevy Truck G 10,20,30 Vans V8-305 5.0L
1990 Chevy Truck G 10,20,30 Vans V8-350 5.7L
1990 Chevy Truck G 10,20,30 Vans V8-454 7.4L
1990 Gmc Truck C+k 1500 - 3500 Pu V8-454 7.4L
1990 Gmc Truck Jimmy/yukon Ful Size V8-350 5.7L
1990 Gmc Truck G 1500 - 3500 Vans V6-262 4.3L
1990 Gmc Truck G 1500 - 3500 Vans V8-305 5.0L
1990 Gmc Truck G 1500 - 3500 Vans V8-350 5.7L
1990 Gmc Truck G 1500 - 3500 Vans V8-454 7.4L
1991 Oldsmobile Full Size Olds Rwd V8-305 5.0L
1991 Pontiac Firebird V8-305 5.0L
1991 Pontiac Firebird V8-350 5.7L
1991 Oldsmobile Truck Bravada V6-262 4.3L
1991 Buick Full Size Buick Rwd V8-305 5.0L
1991 Cadillac Full Size Cad Rwd V8-305 5.0L
1991 Cadillac Full Size Cad Rwd V8-350 5.7L
1991 Chevrolet Full Size Chevrolet V8-305 5.0L
1991 Chevrolet Full Size Chevrolet V8-350 5.7L OHV
1991 Chevrolet Camaro V8-305 5.0L
1991 Chevrolet Camaro V8-350 5.7L OHV
1991 Chevrolet Camaro V6-191 3.1L
1991 Chevy Truck R+v 10,20,30 P/u,sub V8-454 7.4L
1991 Chevy Truck Blazer Full Size V8-350 5.7L
1991 Chevy Truck G 10,20,30 Vans V6-262 4.3L
1991 Chevy Truck G 10,20,30 Vans V8-305 5.0L
1991 Chevy Truck G 10,20,30 Vans V8-350 5.7L
1991 Chevy Truck G 10,20,30 Vans V8-454 7.4L
1991 Chevy Truck P30 Van V6-262 4.3L
1991 Chevy Truck P30 Van V8-350 5.7L
1991 Chevy Truck P30 Van V8-454 7.4L
1991 Chevy Truck S10,t10 P/u,blazer V6-262 4.3L
1991 Gmc Truck Jimmy/yukon Ful Size V8-350 5.7L
1991 Gmc Truck G 1500 - 3500 Vans V6-262 4.3L
1991 Gmc Truck G 1500 - 3500 Vans V8-305 5.0L
1991 Gmc Truck G 1500 - 3500 Vans V8-350 5.7L
1991 Gmc Truck G 1500 - 3500 Vans V8-454 7.4L
1991 Gmc Truck P3500 Van V6-262 4.3L
1991 Gmc Truck P3500 Van V8-350 5.7L
1991 Gmc Truck P3500 Van V8-454 7.4L
1991 Gmc Truck S+t15,sonoma Pu - Jimy V6-262 4.3L
1992 Oldsmobile Full Size Olds Rwd V8-305 5.0L
1992 Oldsmobile Full Size Olds Rwd V8-350 5.7L
1992 Pontiac Firebird V8-305 5.0L
1992 Pontiac Firebird V8-350 5.7L
1992 Pontiac Firebird V6-191 3.1L
1992 Buick Full Size Buick Rwd V8-350 5.7L
1992 Cadillac Full Size Cad Rwd V8-305 5.0L
1992 Chevrolet Full Size Chevrolet V6-262 4.3L
1992 Chevrolet Full Size Chevrolet V8-305 5.0L
1992 Chevrolet Full Size Chevrolet V8-350 5.7L OHV
1992 Chevrolet Camaro V8-305 5.0L
1992 Chevrolet Camaro V8-350 5.7L OHV
1992 Chevrolet Camaro V6-191 3.1L
1992 Chevy Truck Blazer Full Size V8-350 5.7L
1992 Chevy Truck G 10,20,30 Vans V6-262 4.3L
1992 Chevy Truck G 10,20,30 Vans V8-305 5.0L
1992 Chevy Truck G 10,20,30 Vans V8-350 5.7L
1992 Chevy Truck G 10,20,30 Vans V8-454 7.4L
1992 Chevy Truck P30 Van V6-262 4.3L
1992 Chevy Truck P30 Van V8-350 5.7L
1992 Chevy Truck P30 Van V8-454 7.4L
1992 Gmc Truck Jimmy/yukon Ful Size V8-350 5.7L
1992 Gmc Truck G 1500 - 3500 Vans V6-262 4.3L
1992 Gmc Truck G 1500 - 3500 Vans V8-305 5.0L
1992 Gmc Truck G 1500 - 3500 Vans V8-350 5.7L
1992 Gmc Truck G 1500 - 3500 Vans V8-454 7.4L
1992 Gmc Truck P3500 Van V6-262 4.3L
1992 Gmc Truck P3500 Van V8-350 5.7L
1992 Gmc Truck P3500 Van V8-454 7.4L
1993 Oldsmobile Truck Bravada V6-262 4.3L
1993 Buick Full Size Buick Rwd V8-350 5.7L
1993 Chevrolet Full Size Chevrolet V6-262 4.3L
1993 Chevrolet Full Size Chevrolet V8-305 5.0L
1993 Chevrolet Full Size Chevrolet V8-350 5.7L OHV
1993 Chevy Truck C+k 1500 - 3500 P/u V8-350 5.7L
1993 Chevy Truck Blazer Full Size V8-350 5.7L
1993 Chevy Truck G 10,20,30 Vans V6-262 4.3L
1993 Chevy Truck G 10,20,30 Vans V8-305 5.0L
1993 Chevy Truck G 10,20,30 Vans V8-350 5.7L
1993 Chevy Truck G 10,20,30 Vans V8-454 7.4L
1993 Chevy Truck P30 Van V6-262 4.3L
1993 Chevy Truck P30 Van V8-350 5.7L
1993 Chevy Truck P30 Van V8-454 7.4L
1993 Gmc Truck C+k 1500 - 3500 Pu V6-262 4.3L
1993 Gmc Truck Jimmy/yukon Ful Size V8-350 5.7L
1993 Gmc Truck G 1500 - 3500 Vans V6-262 4.3L
1993 Gmc Truck G 1500 - 3500 Vans V8-305 5.0L
1993 Gmc Truck G 1500 - 3500 Vans V8-350 5.7L
1993 Gmc Truck G 1500 - 3500 Vans V8-454 7.4L
1993 Gmc Truck P3500 Van V6-262 4.3L
1993 Gmc Truck P3500 Van V8-350 5.7L
1993 Gmc Truck P3500 Van V8-454 7.4L
1994 Oldsmobile Truck Bravada V6-262 4.3L
1994 Chevy Truck Blazer Full Size V8-350 5.7L
1994 Chevy Truck G10 Van V6-262 4.3L
1994 Chevy Truck G10 Van V8-305 5.0L
1994 Chevy Truck G20 Van V6-262 4.3L
1994 Chevy Truck G20 Van V8-305 5.0L
1994 Chevy Truck G20 Van V8-350 5.7L
1994 Chevy Truck G30 Van V6-262 4.3L
1994 Chevy Truck G30 Van V8-350 5.7L
1994 Chevy Truck G30 Van V8-454 7.4L
1994 Chevy Truck P30 Van V6-262 4.3L
1994 Chevy Truck P30 Van V8-350 5.7L
1994 Chevy Truck P30 Van V8-454 7.4L
1994 Gmc Truck Yukon V8-350 5.7L
1994 Gmc Truck G1500 Van V6-262 4.3L
1994 Gmc Truck G1500 Van V8-305 5.0L
1994 Gmc Truck G2500 Van V6-262 4.3L
1994 Gmc Truck G2500 Van V8-305 5.0L
1994 Gmc Truck G2500 Van V8-350 5.7L
1994 Gmc Truck G3500 Van V6-262 4.3L
1994 Gmc Truck G3500 Van V8-350 5.7L
1994 Gmc Truck G3500 Van V8-454 7.4L
1994 Gmc Truck P3500 Van V6-262 4.3L
1994 Gmc Truck P3500 Van V8-350 5.7L
1994 Gmc Truck P3500 Van V8-454 7.4L
1995 Chevrolet Corvette V8-350 5.7L OHV
1995 Chevy Truck Astro Van V6-262 4.3L
1995 Chevy Truck G10 Van V6-262 4.3L
1995 Chevy Truck G10 Van V8-305 5.0L
1995 Chevy Truck G20 Van V6-262 4.3L
1995 Chevy Truck G20 Van V8-305 5.0L
1995 Chevy Truck G20 Van V8-350 5.7L
1995 Chevy Truck G30 Van V6-262 4.3L
1995 Chevy Truck G30 Van V8-350 5.7L
1995 Chevy Truck G30 Van V8-454 7.4L
1995 Chevy Truck Blazer (s10) V6-262 4.3L
1995 Chevy Truck Tahoe V8-350 5.7L
1995 Chevy Truck P30 Van V6-262 4.3L
1995 Chevy Truck P30 Van V8-350 5.7L
1995 Chevy Truck P30 Van V8-454 7.4L
1995 Gmc Truck Safari Van V6-262 4.3L
1995 Gmc Truck Yukon V8-350 5.7L
1995 Gmc Truck G1500 Van V6-262 4.3L
1995 Gmc Truck G1500 Van V8-305 5.0L
1995 Gmc Truck G2500 Van V6-262 4.3L
1995 Gmc Truck G2500 Van V8-305 5.0L
1995 Gmc Truck G2500 Van V8-350 5.7L
1995 Gmc Truck G3500 Van V6-262 4.3L
1995 Gmc Truck G3500 Van V8-350 5.7L
1995 Gmc Truck G3500 Van V8-454 7.4L
1995 Gmc Truck Jimmy V6-262 4.3L
1995 Gmc Truck P3500 Van V6-262 4.3L
1995 Gmc Truck P3500 Van V8-350 5.7L
1995 Gmc Truck P3500 Van V8-454 7.4L
1996 Chevy Truck G30 Van V6-262 4.3L
1996 Chevy Truck G30 Van V8-350 5.7L
1996 Chevy Truck G30 Van V8-454 7.4L
1996 Chevy Truck P30 Van V8-454 7.4L
1996 Gmc Truck G3500 Van V6-262 4.3L
1996 Gmc Truck G3500 Van V8-350 5.7L
1996 Gmc Truck G3500 Van V8-454 7.4L
Napa mod # PP25 ? $57.00
good info here
#D1943a
10482827
Is there a auto app. HEI without a vacuum advance that you can pick up from Auto zone? And, if it is an older carb. motor can you wire in a module? Or is there an HEI available that has an internal module (like the Mallory one wire style)?
