would this 540 be a good buy? >
Old 08-19-2011 | 07:47 AM
Originally Posted by stevesxm
well... parts are parts but unless the guy doing the building has some skills, you could easily be buying shiny new junk. i particularly like the " SHOULD make 600 hp.." seems to me that you go thru that sort of effort, then you pay for the dyno days so the motor actually has some credentials to support the claims...
I totally agree with stevesxm...this coming from a consumer...not a builder. It seems to me that if a professional "shop" builds an engine like this the buyer should get some kind of Quality Control documentation (dyno sheet) showing exactly what kind of HP/Torq the engine is capable of generating. The shop may build great street engines, but how many marine engines have they built, etc. Good luck with whatever you decide, but do due diligence.
Thunderstruck27 is offline
Old 08-19-2011 | 08:43 AM
Sounds like a decent price, I would be concerned about the cam. Get the cam specs and post them here. If it is not marine specific, it will most likely need to be changed. A 540 with Dart heads should make well over 600HP with the correct cam.
jeffswav is offline
Old 08-19-2011 | 11:12 AM
Inconel exhaust valves are a must on a marine high performance engine.
Bob
Full Throttle Marine
bobl is offline
Old 08-19-2011 | 11:36 AM
.566"/.566"
112 LS
I would think being a 540 it could use more lift.
picklenjim is offline
Old 08-19-2011 | 05:28 PM
That cam is Weeeeek !!!! The cam in my 489 is bigger than that.
jeffswav is offline
Old 08-19-2011 | 05:42 PM
Is that duration at .050? If so, that is waaayyy to much duration for a marine engine, even with dry exhaust.
Philm is offline
Old 08-19-2011 | 06:31 PM
It has to be advertised....
jeffswav is offline
Old 08-19-2011 | 06:42 PM
i could not find cam specs and i googled it a bunch of times. this motor wont sell fast either around here. so maybe ill get it cheaper
zeke is offline
Old 08-19-2011 | 08:06 PM
Originally Posted by picklenjim
296/302
.566"/.566"
112 LS
Where did these come from?
jeffswav is offline
Old 08-19-2011 | 08:52 PM
http://www.compcams.com/Company/CC/c...?csid=450&sb=0
hopefully you cam pro's can tell me if this cam would work or not
zeke is offline
