Compression test questions >
Old 08-19-2011 | 02:47 PM
bcfountain's Avatar
Registered User
i say do the test yourself.if you pluck it up,you got nobody to blame but yourself,at least you will learn.i have to agree w/dennis ,why would anyone drive a ford or a harley?lol jus kidding guys.
bcfountain is offline
Old 08-19-2011 | 02:51 PM
Originally Posted by Dennis Moore
Steve,
I've got a feeling there are a lot of things "you just don't get"
I don't get why people would ever own a Ford, why anyone would ever vote Re-buba-lican and why anyone
would ride a Harley.
But I bet stevesxm does those things.
Ha Ha
Dennis
yes. there are a lot of things i don't get. and for sure, stupid for the sake of being stupid is one of them. and dennis, for the record, like it or not, your politics, car of choice or motorcycle preferance not withstanding, when a guy tries to hire someone to do the work for him because he wants a professional opinion ( smart) and asks a most basic question that might suggest he is unsure of the procedure ( his words )
then your advice that he do it himself because " what can it hurt" is stupid. and i don't care how many books you wrote 30 years ago.
stevesxm is offline
Old 08-19-2011 | 05:03 PM
articfriends's Avatar
"then your advice that he do it himself because " what can it hurt" is stupid. and I DON'T CARE HOW MANY BOOKS YOU WROTE 30 YEARS AGO!!"
Steve, will you adopt me??? YOU ARE MY HERO!!!!!!
articfriends is offline
Old 08-19-2011 | 05:09 PM
Originally Posted by T-RAV
It's not like I am mechanically dumb, I just read conflicting information and wanted conformation. I did fiberglass and gel work for 5 years through college. Which wasn't that long ago! So I feel I am capable, thanks for the waste of bandwidth steve.
T-rav-find someone qualified and do a full survey, transom replacements are exspensive and should really be checked for moisture on a 14 year old boat and they could check compression and hopefully do a leakdown test too as the 502 mpi's used metric low tension rings and are prone to leakdown problems stock. If you do it yourself pull the fuel pump fuse or unplug distributer signal wire and un-plug the coil so you don't burn up the coil (I have done this) and you don't wash motor with a bunch of fuel every time you crank it over, Smitty
Old 08-19-2011 | 05:23 PM
There is a certain speed that is expected with every make and model of boat depending on the HP. If the boat does not hit that mark then somthing should be looked at.
Listen for a mis under load and listen for anything unusual. The transom and stringers should be looked at, take a rubber mallet and tap around, listen for hallow or different tones. If you can get a moisture meter that would help.
jeffswav is offline
Old 08-19-2011 | 05:47 PM
onesickpantera's Avatar
I don't think the OP was saying him doing a compression test himself will replace a full blown survey. I think he was simply asking if he chooses to do a comp test himself should the engine be warm or cold.
IMO warm is better as problems show up as the metal expands. But the problem is too warm and it's a PITA on a boat.
I always check my sleds warm as they are obviously easy to get to the plugs. I've seen wounded sleds have decent compression cold then warm them up and it drops significantly. But ask 5 people the proper method and you'll get 5 answers. Some say warm, some say cold, some say throttle wide-open, some say it doesn't matter, some say 3 pulls, some say pull until the gauge quits going up, etc, etc.
Smitty gave you good advice. And don't get hung up on the actual number as gauges can vary(unless they are all very low then try a different gauge). The important part of a compression test is the difference between the cylinders.
onesickpantera is offline
Old 08-19-2011 | 05:48 PM
And what's wrong with a guy doing his own comp test? If a boat I was thinking about buying was near me I would check it out first myself. If it checked out then I may have someone more experienced survey it. If it doesn't they you simply walk away and save yourself the money for a survey. Seems logical.
Old 08-20-2011 | 04:43 PM
Lee's Avatar
Lee
Steve,
Ha Ha
Dennis
Because they are smarter than you.
Lee is offline
Old 08-20-2011 | 05:27 PM
+1 that's awful rude of him
Fixxxer22 is offline
