valves
Old 08-20-2011 | 12:01 AM
Default valves
can you run severe duty stainless valves in a boat or do they got to be inconal??????
zeke is offline
Old 08-20-2011 | 12:55 AM
You can run them, but you would better off with inconnel exhaust valves.
Griff is offline
Old 08-20-2011 | 12:58 AM
Fenderjack's Avatar
Pirate of the Chesapeake
Like said stainless is fine, intake esp, but it is better to run a inc exhaust valve..
John jr
Fenderjack is offline
Old 08-20-2011 | 10:09 AM
Zeke,
It really depends on the horsepower output of the engine. Most of the lower horsepower Mercruiser engines have nothing more than stock GM automotive & truck type valves in them. The higher HP Big Blocks have Manley severe duty intakes and Manley Inconel exhausts. If you are just doing a mild upgrade, almost any decent Stainless valve should be ok. I would stay away from the "cheap" $8 stainless valves. Ferrea has a very good line of valves that are in a "medium" price range. Thier "severe duty" valves are also about as good as you can get.
Hope this helps,
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
BillK is offline
