454 vs 496 Manifolds and Risers >
Old 09-01-2011 | 06:47 AM
Are all 496 manifolds and risers the dry system?
Warrior II is offline
Old 09-01-2011 | 01:04 PM
That is, wet joint to dry joint.
Old 09-01-2011 | 01:19 PM
Knot 4 Me's Avatar
Yes. Dry joint between the manifold and riser.
Knot 4 Me is offline
Old 09-01-2011 | 10:37 PM
Would going from a wet joint to a dry joint make it run hotter?
Old 09-01-2011 | 11:03 PM
Just install them.
MIE 340 stroked into a 496. Simple bolt on and run.
f_inscreenname is offline
Old 09-02-2011 | 10:06 AM
JBravo's Avatar
How about from a 2004 496HO "closed cooling" to a 1996 454 7.4L?? I have read all thee above. Should bolt rtg up.
Thanks, John
JBravo is offline
Old 09-02-2011 | 11:23 AM
Originally Posted by HTRDLNCN
we switched from merc 454 stockers to the 496 manifolds on a 454 Mag and had to change absolutely nothing, didnt have to change hoses,drill holes, make holes bigger, zero,it was a straight up swap..
Yes the outlet is a bit angled down but nothing the exhaust hose cant handle.
Did you notice any performance improvements? Even if no change, however, just going to the dry joint design and the weight savings would be worth it, IMO.
Budman II is offline
Old 09-02-2011 | 08:26 PM
Hmmm might be worth the fact you cab remove the valve covers to fix leaks. Mine can't......well on three, one is newer and stands off a bit.
TDSracing is offline
