Prop/Stern Lift??? >
Prop/Stern Lift???
Prop/Stern Lift???
Old 06-07-2002 | 09:00 PM
BAD-HABIT's Avatar
Default Prop/Stern Lift???
What prop should I try if I want to increase stern-lift? Seems like everyone likes props that increase bow-lift but my boat seems to prefer some stern-lift for top mph.....I am running a Michigan Ballistic which works better at mid-top end. The Mirage planes and accellerates better to about 3500 rpm's....
"Bad-Habit"
BAD-HABIT is offline
Old 06-07-2002 | 09:13 PM
cuda's Avatar
If yours has a hook like mine, it would seem it would like bow lift more since the hook is keeping the bow down. I just sent a check for a 21 cleaver to try on mine. I have a 23 cleaver on it now.
cuda is offline
Old 06-07-2002 | 09:35 PM
Wow; this could be a long talk. In general "cleaver" props develope the most stern lift. Merc. Mirage will give you the most Bow lift. However, there is NO prop that will compensate for a hull problem. BEFORE YOU BUY MORE PROPS, CHECK OUT YOUR HULL!!! Been there-done that!! --- Jer
jpclear is offline
Old 06-07-2002 | 09:45 PM
Now, I'm going to try to make this easy. Just like you can't tune out bad compression on #7 cyl. by adjusting the carb, you can't fix a hull problem by changing props. --- Jer
jpclear is offline
Old 06-07-2002 | 10:00 PM
BAD-HABIT's Avatar
Well Jp me and "Cuda" have the same hulls. Our Formula's have a "hook" built in. A dead cylinder is probally not a good comparison. I think it would be more like a how some race cars have more down-force than outhers. The built in "hook" provides a more stable ride than some outhers but at the expense of top-end. Wouldn't a hook cause the stern to squat. I would think that "bow-lift" is worthless if you can't get the ass-end loose. Hell isn't it kind of like a stepped hull vs. a non-stepped hull? A cat vs. a deep "v"?
"Bad-Habit"
Old 06-07-2002 | 10:02 PM
cuda's Avatar
I'm going with the cleaver because I have been told it will minimize the heeling to port. I haven't really tried out the 23 cleaver that is on there, but when I took it out with 4 people and a full tank, it was a ***** getting on a plane. Now that I have another boat coming, I can afford some down time on the 20, so I might try to take the hook out of it myself. I know I can float a wavy floor out enough that you can sit a marble anywhere on it and it won't roll.
cuda is offline
Old 06-07-2002 | 10:26 PM
MACDAD260's Avatar
Charter Member #818
A hook in the hull will cause stern lift. You need a prop with bow lift to compensate for the hook. A 4 blade prop will generally provide more stern lift than a 3 blade. Sounds like you need something like a 3 blade Mirage+. Also, more cup in the prop will cause stern lift, too. This has been my experience.
MACDAD260 is offline
Old 06-07-2002 | 10:46 PM
Cuda, you don't have tabs to compensate for "Heeling"??. Man, we are going to start from the very beginning here. But I can tell you this: When it is all set up right , at WOT the tabs are UP and the boat "HANGS" in the air. About 2 sq. ft. of the a$$ wetted. I cuold send some pics if I need to prove this. --- Jer
jpclear is offline
Old 06-09-2002 | 10:23 AM
syringa
Just my 2 cents guys.>> I repowered a 208 Baja Islander with a 502 (500 hp) and had some serious handling problems. I admit some of the problems are in the hull but>>> I tried the whole gambit of Mercury props, Mirage, Vengenance,Bravo I, Trophy, and Lazer II. The prop that worked the best for me was the Laser II. I know it's a prop mainly designed for outboard bass boats but if you want to get the bow up you need a high rake prop to push the stern down ,small diameter 3 blade worked better than 4 blade, smaller diameter worked better than large. If you can get your mitts on one try it Again just my 2 cents
syringa
Old 06-09-2002 | 10:41 AM
syringa
I misread the post i thought you were speaking of bow lift.
syringa
