I'm screwed............. >
Old 08-26-2011 | 07:50 PM
Default I'm screwed.............
Doing some maintenance on the boat so I can take the kids out this weekend, changing impeller, somehow misplaced the "keyway" that locks the impeller onto the pump housing shaft.....I have looked on line and can not find a part number, replacement....any ideas? Thanks, Jeremy
FogduckerIII is offline
Old 08-26-2011 | 08:49 PM
Default fixx
Jeremy,shame on you and you should know that the bravo shaft on the pump is D shaped and so in the impeller..
BTW look at all the chit your x turned up on the east coaste..
FIXX is offline
Old 08-26-2011 | 10:25 PM
Have no idea what your working on but here's one that might be it. Part #11
http://www.perfprotech.com/store/ass....aspx#assembly
picklenjim is offline
Old 08-26-2011 | 10:48 PM
Its just a key. Did you try an Ace Hardware or Home Depot type store. They should only be about a dollar or less.
baja_brian is offline
Old 08-26-2011 | 11:26 PM
Randy Nielsen's Avatar
That looks like an old style bravo pump if the key is a round pin try a hardware store for some round steel stock, if a d shaped key try a small engine shop
Randy Nielsen is offline
Old 08-26-2011 | 11:32 PM
Thanks boys, as Fix pointed out, probably didn't have a key to begin with, having said that, interesting post picklenjim made about part number 11.....seems there is a "key" option for the Bravo pump...?
baja_brian, I don't think you would find the tapered keyways for any marine application at a hardware store........
Old 08-27-2011 | 02:16 AM
Default fixx
#11 is the rubber cap that goes in the end of the inpeller...
FIXX is offline
Old 08-27-2011 | 11:19 AM
No, thats the key. They came both ways.May be quicker to just get the impeller that doesn't use the key. Here's a better picture of it on an outboard. Part #24. They were used on several different applications.
http://www.crowleymarine.com/mercury...ts/412_160.cfm
Blow the picture up with the + at the bottom. Scroll down and you will see the part number.
Old 08-27-2011 | 12:28 PM
My bad, I am refering to an engine mounted Bravo sea water pump, after talking to Fix and looking carefully at what I have I realize it does not have a "key" I assumed it did and that I had lost it while taking it apart....
Thanks for all the input, I will slink back into my garage...........
Old 08-27-2011 | 01:04 PM
Some of them had them also. All depends on the impeller your using.
