Oil cooler
I wanted to say that too
BUT everytime I do I get attacked! I wrote a VERY informative thread on just this years ago based on personal experience, I know that YOU know the drill, Smitty
http://www.offshoreonly.com/forums/g...-hardware.html
BUT everytime I do I get attacked! I wrote a VERY informative thread on just this years ago based on personal experience, I know that YOU know the drill, Smittyhttp://www.offshoreonly.com/forums/g...-hardware.html
How hard and how long do you have to lean on an engine before you start to see oil temp issues? I am still running the smaller stock cooler on my 489, but I did upgrade to #10 Aeroquip lines, and I also eliminated the stock remote oil filter adapter and went with a sandwich adapter for the filter that has a built-in T-stat. I also made sure the 30 lb bypass was installed. I am taking my oil temp reading from the pan, and I usually read about 195* when just cruising around. The engine only has about 10 hours on it, so I have been going easy on it, but so far I have run it up to about 4500 RPM's for a few minutes at a time, and the highest temp I have seen is around 220*. I think I am all right with this setup, as I am not running any poker runs or extended WOT runs, but I will be watching the gauge closely. I figured I could always add the bigger cooler down the road if I needed it, but so far the bigger lines and less restriction seem to be doing the trick. As I mentioned before, the folks who like to hold theirs wide open for 10 - 15 minutes at a time or longer will almost certainly need a bigger cooler.
Any thoughts are welcome. I too would love to see a larger cooler that would mount in the stock location without the need for fabricating a lot of custom water and oil lines. In the past I have just made up my own water line by rooting through the stock at the local NAPA until I found one with the approximate bends and diameters that I needed. I think I had to put one splice with some clamps to put two sections together. I wonder if someone makes some type of corrugated water line that could easily be flexed and routed that would hold up well.
