VDO Fuel Sender
VDO Fuel Sender
Would anyone have a VDO Tube type fuel sender (224-064) for sale, or know where I can get one? It fits a 1987 Formula 242LS. On the top of the sender are the numbers: 82/5/137 which cross to the Formula number listed above.
Mine quit because of corrosion (Thanks again ethanol) but is all there. I took it apart and found the wire had broken and is not long enough to solder back on. If anyone knows the type of wire it uses, I can fix it.
Thanks,
Bill
Thanks,
Bill
Found one at eGauges. If anyone else has the problem Mac is a great guy to work with. Also, NSI was able to to cross the number and would have been able to make one up. I went with eGauges cause I called them first. Better price to boot.
