Pricing for Hydraulic Steering >
Old 09-20-2011 | 08:29 AM
PSC has all kinds of hydraulic steering components, mostly for off road, but the steering valves are a great price.
http://www.pscmotorsports.com/motors...teering-valves
Also check out Everett Performance @
http://www.everettperformance.com/
ThisIsLivin is offline
Old 09-20-2011 | 08:54 AM
So tell me what cc" unit should you need for a single system and how do you determine that?..................................Rjr........ .......................
Robertjr is offline
Old 09-20-2011 | 02:36 PM
bcfountain's Avatar
Registered User
do not want tostep on anybodys thread,or sound dumb.but what all is needed for full hyd steering.i have factory hyd streeing with a cable helm.what do i need to make it fullhyd steering?
bcfountain is offline
Old 09-20-2011 | 03:02 PM
Dave M's Avatar
Veteran: Navy
There is a table in the IMCO catalog that shows helm size / ram stroke, in relation to "lock-to-lock" of your steering.
I had a single ram system that normally uses the 95cc helm, but I used the 120cc with the thought of adding another ram. I never did add the ram, but the steering worked great.
Dave M is offline
Old 09-20-2011 | 03:06 PM
Dave M's Avatar
Veteran: Navy
Sounds like you have what is known as an add-on system. Before I converted to a full system, I still had some play in the steering. Once I added the helm, it made a big difference in the precision of the steering.
Dave M is offline
Old 09-20-2011 | 04:27 PM
Just received my parts. Basically you are going to need a helm, steering post, filter, and a bunch of fittings and hydraulic hose. Some say you need a additional tank for fluid capacity and others say its not needed. Imco has an add on kit to complete your current set up to full Hydraulic and CP Performance has a kit made by Mayfair Marine. After a bit of researce I chose the Mayfair kit, it was about $500cheeper and came with the additional tank, and appeared to be a more complete set up IMO, I will see shortly.
tbanzer is offline
Old 09-20-2011 | 04:31 PM
Originally Posted by Dave1972
tbanzer,
I have a friend of mine that makes everything and is higher quality cylinders and hardware than any of them. Custom machine shop that makes most of the steering/suspension components for the big monster trucks. You can reach him via email--sstoutlaw at yahoo dot com (I think) or send me a PM and I can give you his number. Great guy to work with!
I wish I would have got your response sooner I already researched, purchased last week, and got my stuff today.
tbanzer is offline
Old 09-21-2011 | 07:33 AM
keep us posted....I am needing to do this now...so with dual rams a 120 pump should do the trick ? thanks
ezstriper is offline
Old 09-21-2011 | 12:22 PM
swan2's Avatar
I need to add a completed external system. I have just the cable set up. What would something like that cost and is this something I can do myself? Im mechanicaly inclined and was wounding if this stuff in difficult to do as I would like to save some money by doing it myself. Do these system come with step by step instructions if bought complete? Thanks for the help
swan2 is offline
