-   -   Fixing my Bravo skeg (https://www.offshoreonly.com/forums/general-q/262531-fixing-my-bravo-skeg.html)
Toofast 09-18-2011 03:40 PM
Hey guys, just curious what you might recommend to fix this skeg. I really don't want a Stainless guard...
http://i131.photobucket.com/albums/p...s/IMG_7847.jpg
articfriends 09-18-2011 04:21 PM
Look under prop repair and there is always someone who fixes skegs on the boat, locally we got a guy named STANGES prop repair, he welded mine on the boat for about 75 or 100$ 6 or 7 years ago, it can be done , on the boat and no it doesn't burn the oil or bearings in the lower. The guy I mentioned is in Bay city Mi, would be 120 miles from you but I am sure you can find someone locally, Smitty
picklenjim 09-18-2011 04:28 PM
That's not that bad at all. Should be an easy fix at a prop shop.
Toofast 09-18-2011 05:05 PM
Yeah, I just bought it and wanted to make it look nice. The prop is beat up too. What should you expect to pay for a prop job?
blue thunder 09-19-2011 11:29 AM
I have used Marine Tex to fill small voids like the one you show.
Toofast 09-19-2011 11:33 AM
Looks interesting.
4bus 09-19-2011 11:49 AM
I would have the prop shaft inspected as well. Does the up trim work? :lolhit::lolhit:
fountainfan42 09-19-2011 11:52 AM
Martins CustomMarine in Mich (517) 719-0216
Toofast 09-19-2011 04:45 PM
:angry-smiley-038: yes...
Griff 09-20-2011 12:27 AM
Just take it to anyplace that welds aluminum. They should be able to fill that in easily.
baja_brian 09-20-2011 11:30 AM
I agree with Griff any machine shop that welds aluminum should be able to do them. (they have for me anyway)
Sometimes it is hard to find a replacement skeg locally. I know I have bought them either online or ebay. I think they are about 50 dollars. I am pretty sure bravo I and bravo III use the same skeg.
John the Drive Man 09-20-2011 12:33 PM
I use a welder that puts a new skeg on and you would never know it. And won't cost more than $165 dollars,It's well worth it,
Griff 09-20-2011 01:49 PM
1 Attachment(s)
Personally, I would just grind it off straight and repaint it.
Toofast 09-20-2011 11:02 PM
That's a thought.... it won't change handling or anything I assume?
picklenjim 09-20-2011 11:08 PM
Second that Griff.
c_deezy 09-20-2011 11:27 PM
That's what I would do as well. You probably wouldn't even need to take it all the way up to the bullet, I would just straighten it out as little as possible from the top of the chip down.
Originally Posted by picklenjim (Post 3508249)
Second that Griff.
Griff 09-21-2011 11:03 AM
That small amount won't change a thing.
blue thunder 09-21-2011 04:04 PM
Do the Marine Tex, $10 and you won't even be able to tell its been dinged. If you don't like the marine tex you can alway grind it off flat like suggested above. I personally like the look of the full skeg. Small skegs starts looking like someone is jury rigging stuff. And I've had some small skegs up to and including no skeg at all. BTDT.
Sledge Hammer 09-22-2011 08:41 PM
I did the same thing as Griff suggested without issue. If you just draw a straight line and cut it with a saber saw it is easy. Then dress the edge with a file or disc grinder. The marine tex would work fine as well. Sand smooth and paint. No real need to weld it.
