Running temp on an 03 496 >
Old 09-26-2011 | 08:29 AM
Default Running temp on an 03 496
I have an 03 baja with twin 496s. What should the running temp be? Right now it's at 170.
Eleanor is offline
Old 09-26-2011 | 08:37 AM
Mine sits between 156 and 163. 163 when idling. I believe the thermostat is 160 degrees.
Dan
BajaDan is offline
Old 09-26-2011 | 09:16 AM
I've changed the water pumps,cleaned the heat exchangers and it's still the same. Is there something else I should be looking at or changing? They don't fluctuate much,a couple degrees but for the most part remain around 170
Eleanor is offline
Old 09-26-2011 | 09:18 AM
Dave M's Avatar
Veteran: Navy
That's perfectly normal. Mine always ran around 170, regardless of air or sea water temp.
Dave M is offline
Old 09-26-2011 | 09:29 AM
Knot 4 Me's Avatar
Mine runs right at 160 +/- a few degrees. After a hard run it will run up to about 175 or so at idle and then cool back down after a bit.
Knot 4 Me is offline
Old 09-26-2011 | 10:30 AM
Yours seems to run 180-185 no? i think thats too high...
THE OUTLAW is offline
Old 09-26-2011 | 04:30 PM
mine run right at 170 all the time
Allicat38 is offline
Old 09-26-2011 | 06:25 PM
Same here.
Twin-Kyle is offline
Old 09-26-2011 | 09:24 PM
Default 496 temps
Dang, mine runs 160-170 and after running and then back directly to idle i am at 185 degrees (water in the south is 85-88 degrees also)! EVERYTHING is new and no blockages anywhere! No alarms, no idea what to check next.
baja25sst is offline
