transom moisture >
transom moisture
transom moisture
Old 09-27-2011 | 06:00 AM
Default transom moisture
HI i have a survey on my boat yesterday,2001 baja 272.i buy it new.boat is NO 1 exept i have moisture in the transom,but the guy said it still very strong.boat never stay in water but it is on a not heating garage in winter(canada)is there something i can do to control the moisture. thanks.
zx14k is offline
Old 09-27-2011 | 06:11 AM
I am NOT a surveyor but I remember doing som reading on the subject and depending on the amount of moisture it may not be an issue. some surveyors dont even like the moisture meter.
How much moisture?
JB33 is offline
Old 09-27-2011 | 06:14 AM
I would worry if there was a difference in reading from one area to another, like if the area at the stern drive was much higher.
pitts1313 is offline
Old 09-27-2011 | 06:19 AM
It does not have to stay in water long to get water in if you do not have a good seal somewhere...where was the water detected ? sometime right around gimbal housing...trim tab ?? need to pull that of repair and reseal...transom goes so will your $$$$$
ezstriper is offline
Old 09-27-2011 | 07:13 AM
pull both of your exhaust tips out of the boat and inspect the actual wood in your transom in that area, then reseal them properly and re-install. The older bajas had no epoxy in any of the holes they cut through the boat (ex holes , transom cutout, ETC) any leaks at these areas lets the water right into the middle of the wood, not sure if your year baja had epoxy over the holes they cut or not??
you could also drill into your transom about 1.25" deep in a few area and inspect the condition of the wood coming out on the drill. some areas that are easy to do this and hide the holes afterwards are by removing anything mounted to the inside of your transom and drill where that item was mounted, then seal the hole back up with epoxy and re-install the item on the transom.
goodd luck!
gsxr1216 is offline
Old 09-27-2011 | 09:14 AM
Were there's water there's rot. My boat never sits in the water and looks like new. The trim tab screws leakes and rotted over half the transom. Take a rubber mallet and tap on the outside of the transom. If you have to pay to have it replaced you are talking thousands of dollars. I replaced mine myself and it took at least 30hrs. A shop may be able to do it quicker but still very expensive to do it right. I raised my X dim up 3" and recut the hole, beefed up the stringers and shot new gel.
jeffswav is offline
Old 09-27-2011 | 09:22 AM
cost me $5000 on scarab 22 to replace transom due to an epoxy run that kept the gimbal housing from sealing. Water leaked in to the unsealed cuts in the transoms each use. The wood was not even treated in the transom. I never knew it and it was always dry stored.
Old 09-27-2011 | 09:48 AM
A little moisture isn't a big problem, but could be eventually. Moisture from saltwater doesn't typically rot the wood, but freshwater does. Makes a big difference in what type of wood is used. If its treated good strong wood then it should hold up for a long time even if it does have moisture. If its cheap untreated wood, which is pretty likely in the baja, then it will rot much faster.
TexomaPowerboater is offline
Old 09-27-2011 | 11:46 AM
bcfountain's Avatar
Registered User
i am no expert,but when water gets into the wood,it is a pain in the dick to get out,and very expensive.jus my 2cents
bcfountain is offline
Old 09-27-2011 | 06:52 PM
thanks for all replys i will look deeper and see what i can do.
zx14k is offline
