Steering issue? >
Steering issue?
Steering issue?
Old 09-29-2011 | 01:54 PM
Default Steering issue?
Boat is a '93 Check Convincor 251, carbed 502, bravo 1, 24p prop.
When I was out on the lake recently I noticed that when I'm at speed and try and back off of the throttle the boat wants to jump hardcore to the right, almost like it is trying to make a 90* turn. First time it happened I was caught off guard to say the least. The previous owner mentioned something about this, but I didn't notice it at all during the sea trial and didn't really understand what he meant, however NOW lets just say I completely know what he was talking about.
Still, I have no idea what is wrong, all I know is it is not supposed to be like this, and I would like to fix it.
Thanks,
Seth
seth0687 is offline
Old 09-29-2011 | 03:18 PM
swan2's Avatar
Check with the motor not running can you move the drive side to side alot. If so and it does not have external steering then its going to need the gimble ring and pin replaced.
swan2 is offline
Old 09-29-2011 | 03:32 PM
Do you mean see if I can move the WHOLE lower unit as if I was steering it with my hands, or just the prop side to side? Sorry to sound dumb, but I am SUPER green with all this stuff. Also how much force should I try and exert?
Thanks,
Seth
seth0687 is offline
Old 09-29-2011 | 04:03 PM
jjj
The whole drive - see how far left & right it moves without the steering wheel moving.
jjj is offline
Old 09-29-2011 | 04:47 PM
sounds like the gimbal is worn and or the steering actuator(valve at the end of the steering cable) how fast are you running ? did you trim down a bunch when got out of throttle ? these boats very sensitive to trim...
ezstriper is offline
Old 09-29-2011 | 05:04 PM
DiamondPerformance's Avatar
Offshoreonly Advertiser
I had that happen before, check your fluid.
www.diamondperformanceparts.com
[email protected]
http://www.facebook.com/pages/Diamon...07878772615803
302-521-0123
The Best Parts & Service At The Best Price
DiamondPerformance is offline
Old 09-29-2011 | 05:38 PM
All of the above......
That said, my 23 Nova has add on hydraulic and is tight as can be, but it will do similar to yours if I cut the throttle back too fast . No problem at all when I back off more slowly.
Kidnova is offline
Old 09-29-2011 | 07:49 PM
Worn gimbal it happened to me, man it scares the hell of you when it happens. Dont drive it anymore until you figure it out, at high speed it could toss you out of the boat. But thats just my opinion
firehawkcat is offline
Old 09-30-2011 | 06:41 PM
worn gimble and/or worn steering box. Steering and cable is easy and cheap to replace, gimble ring....not so much....
dagah2x is offline
Old 10-02-2011 | 08:49 PM
I am able to move the whole drive about 3-5'' in either direction with the motor off.
As far as speed, I am running between 45-55, haven't been able to get ahold of a hand held GPS yet, to get an exact speed.
Thanks,
Seth
seth0687 is offline
