mobil or amsoil >
mobil or amsoil
mobil or amsoil
Old 10-06-2011 | 05:37 PM
  #31
Originally Posted by weldcrane
15/40 in a gas motor?
Yeah, why not? You can use any diesel oil in a gas motor, just not any gasoline oil in a diesel.
07DominatorSS is offline
Old 10-06-2011 | 07:19 PM
  #32
weldcrane's Avatar
didnt know if there were different additives for diesel as for gas
weldcrane is offline
Old 10-06-2011 | 11:13 PM
  #33
Well, there is different additives for diesel, to control the soot and byproducts of combustion, but they are overkill for a gas engine. In a gas application, its just gonna keep that engine that much cleaner.
Old 10-07-2011 | 08:07 AM
  #34
Knot 4 Me's Avatar
I ran the Amsoil 15W40 Marine/Diesel oil in a 454 for a couple of seasons. Great oil.
Knot 4 Me is offline
Old 10-13-2011 | 06:14 AM
  #35
Originally Posted by ThisIsLivin
I wouldn't recommend running a motorcycle oil in your boat engine. Motor cycle oils have less friction modifiers for better clutch performance.
So, what. Does your boat engine have a wet clutch?
Amsoil makes three different types of high Zinc content oil for harder working engines. The reason for the low Zinc in current automotive oils is that the Zinc causes the catalytic convertors to deteriorate.
Don't believe everything you read. I have been using motorcycle oils in all my vechiles for 20+ years and have never replaced a cat. Last car had 257K on the stock exhaust when I sold it.
Ken
minxguy is offline
Old 10-13-2011 | 06:40 AM
  #36
amsoil dominator
innerrage is offline
Old 12-29-2011 | 10:49 AM
  #37
sleek1's Avatar
Any info on Amsoil Z-Rod 20-50 (ZRFQT)? Supposed to have more anti-oxident and corrosion inhibitors. I was thinking of changing from Amsoil AROQT.
sleek1 is offline
Old 12-29-2011 | 06:49 PM
  #38
They are both similar products with the major difference being TBN. The ARO is stronger in that department. But here are links to both spec sheets for you.
http://www.amsoil.com/lit/databulletins/g2212.pdf
http://www.amsoil.com/lit/databulletins/g2883.pdf
Old 12-29-2011 | 08:08 PM
  #39
cigboat1's Avatar
Mobil 1 All the way-------- Used it in most of my boats over the years and Never had a failure.... All my cars also! Easy to get !Even my 34 scarab with nitrous and still never had a failure.
Jim
cigboat1 is offline
Old 12-30-2011 | 06:25 AM
  #40
BONDO10's Avatar
Amsoil 15/50 Dominator Racing Oil. Not cheap,but nothing better.
And I still change it every 15 hours.
BONDO10 is offline
