need only 1-2 mph quickly..(help)
#34
#37
Yes, but there are other ways of reducing slip. I'm not saying it won't work for sure, it's deffinetly worth trying, as I said before. But it's on rare occasions that 5 blades give a speed increase on a setup like yours. I just can't get my head around the fact that the slip on that hull with B1 props can't be brought down. I know Bblades has labbed your prop, but have you talked to Brett about what else could be done. It might only need a little cupping. I think the hydro QIV and QIV-X could be interesting to try. Have you ever tried a set of non-labbed B1's in 30" and 32"? Then there is the last thing to try. Your friend has a set of 28's. You are both spinning the same rpm's and going equally fast. Try hes props as well. Something is apperantly working for him with the stock 28's.
#38
What gets me is when I put my back up bravo-1 28's on I run about the same just higher RPM,,Thought about having those labbed and adjusted up.. but hate to dump the bucks in it and not do anything..Just getting my slip down to 13% would be great could put me at 75-76
#39
here's the deal OSO bro's.. ME and a buddy both have Formula 312 fastech's his all stock 502 mag mpi's, 28 bravo-1 5100-5200rpm
,mine 454 mag mpi's. I run labbed 30 Bravo-1's, Offhore exhaust w/ss risres and a tweeked just a little ECM and vorteck breather. 5100-5200rpm We ran each other twice at Norris lake TN in 49deg weather and were dead even at 73mph, dead even. he had 2 people I had 3.. How can I gain just a little to pass him..? In theroy I should be beating him with the 30's but I'm not, I know you all know some tricks?
Help an OSO brother out,,,
, but it won't hurt to read it.http://www.offshoreonly.com/forums/g...-skeguard.html
