Polishing Exhaust Tips >
Old 10-07-2011 | 10:24 AM
Just use white vinegar and microfiber that 's all I use on my tips. Works great!!
tylogan11 is offline
Old 10-07-2011 | 12:34 PM
+1 on Lime-A-Way
Unless something scuffed up your tips, they look dull due to hard water deposits.
4mulafastech is offline
Old 10-07-2011 | 01:06 PM
waterbum's Avatar
Originally Posted by 07DominatorSS
You want something easy? Honest to god, use the BioKleen Hull Kleener. There is literally no effort. Spray on, and soft brush off and done.
+1 - Super easy and the pipes comes out shiney. Also removes transom soot with just a quck spray and soft brush. Best $20 I've spent on a cleaning product. 1 bottle should last a few years.
waterbum is offline
Old 10-07-2011 | 01:08 PM
Yea, I use the vinegar for daily use. But if they get real bad I use polishing compound.
jeffswav is offline
Old 10-07-2011 | 01:38 PM
I have the air actuated tips to muffle the exhaust note. I beleive they are gill ? They are kinda dull looking. Tried chrome polish on them. Didnt do squat.
Any idea's. I have 3 sets I want to look like new.
45Tripps is offline
Old 10-07-2011 | 01:52 PM
97FASTech's Avatar
Veteran: Army
I use white vinegar and steel wool on chrome tips and also the prop.
97FASTech is offline
Old 10-07-2011 | 02:22 PM
Originally Posted by MILD THUNDER
If they are just crappy looking from the soot/hard water baked on to them, like they said, some "Works" brand toilet bowl cleaner, or what I like to use, "Works" brand tub/shower cleaner. Its like 2-3 bucks a spray bottle at Menards. It sprays on like windex, and works great. Also works from removing scumline and what not.
If you wanna polish them, you can go to sears and get a Rouge buffing kit for your drill. Comes with the Rouge sticks, couple different buffing wheels, for like 10 bucks. After the rouge, a good metal polish. Will look new.
i also use the works toilet boul cleaner.pour it on,brush it,then ronse it off
mike tkach is offline
Old 10-07-2011 | 03:45 PM
+4 on vinegar...has mild acid in it and takes the minerals rite off. I wouldnt spend money on anything before you try it and I personally dont like to use anything stronger than needed. I even keep a spray bottle of it in my boat and give them a quick squirt at the sand bar.
JRider is offline
Old 10-07-2011 | 07:19 PM
I use a metal polish called Wicked. Takes off all exhaust soot and any oxidation.
Got Cigs is offline
Old 10-07-2011 | 07:33 PM
Just tried out the SIMICHROME stuff with my dremel tool. I used the Simichrome and steel wool on the second tip. Asked the lady which one was the better looking tip. Without hesitation she said the one with the SIMICHROME and Dremel. A lot of work but turned out ok. I would rate them an 8.5 out of 10 as far as how well they turned out. I guess being 20 year old tips, they wont be a 10. lol Thanks for all of the feedback and other tricks of the trade I will try tomorrow on the other 2
coolmedown is offline
